Inventor Forum
Inventor 2013 DE: BUG: Export IDW to AutoCAD DWG: Lines/Spline in the drawing.
8 REPLIES 8
Message 1 of 9
Juergen_Wagner
4412 Views, 8 Replies
Problem:
Samplemodel:
1. open baugruppe1.idw > Save copy as: AutoCAD DWG
2. open DWG in ACADM 2013
Result:
8 REPLIES 8
Message 2 of 9
jingyi.liu
in reply to: Juergen_Wagner
Hi Jwagner
I reproduced your issue, it definitely is a bug, thanks for your report, I will log it as a defect.
Jingyi Liu
Inventor Product Manager
Message 3 of 9
Juergen_Wagner
in reply to: jingyi.liu
Message 4 of 9
lark22
The same thing happens when exporting from Inventor 2013 .dwg to Autocad .dwg
Message 5 of 9
did anyone find a solution for this? It's already logged with development from August 2013 but still no solution.
Sašo.
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 6 of 9
jingyi.liu
Hi, All
It seems many users are blocked by the exporting issue. Regarding the data attached in previous post, there is a solution to address the issue. But please pay attention, below change on exporting setting will impact all spline objects, it will replace spline with polylines.  We can't guarantee the results for any cases. Please try belows only when you face exporting issues.
The way to
  • Click option when export AutoCAD dwg file
  • Click next until you see "save configuration" button
  • Select folder and name the file, exit the exporting.
  • Open the configuration file by notepad, find the line " REPLACE SPLINE=NO", change the NO with YES, save the file.
  • Repeat the exporting and click option, but this time load the configuration file you have modified.
  Save exported AutoCAD DWG file, and check the result.
If you still can't solve the issue after changing, please send your dataset to us, it will be very helpful for development team to get the final solution.
Thanks in advance.
Jingyi Liu
Message 7 of 9
SašoPrijatelj
I works!
I wish someone told me this half year ago... I was looking for that "replace splines" option everywhere but in that location.
Thanks.
Sašo.
Message 8 of 9
^_^clovis^_^
I'm using Inventor 2014 pro and the problem remains :
left : inventor | right : autocad and (part) modified ini
Thanks for any help
Message 9 of 9
^_^clovis^_^
in reply to: ^_^clovis^_^
Until a patch is available, I can't bear having a durty dwg Smiley Mad
(defun c:cll( / acadob count aob listSpline alay lPoints nbp p1 p2 okList)
	;remove non Spline
	(setq acadob(vla-get-activeDocument(vlax-get-acad-object)))
	(setq okList
		(ssget "x" '( 	(-4 . "<NOT")(-4 . "<OR")
						(0 . "SPLINE")
					(-4 . "OR>")(-4 . "NOT>"))
	;change Spline
	(setq count 0)
	(repeat (sslength okList)
		(setq aob (vlax-ename->vla-object(ssname okList count)))
		(vla-put-visible aob 0)
		(setq count (1+ count))
	(defun makeLine ( point1 point2 lay / )
		(entmake
			(list
				'(0 . "LINE")
				'(100 . "AcDbEntity")
				(cons 8 lay)
				'(100 . "AcDbLine")
				point1
				point2
	(Prompt "\nSelect Spline to change..")
	(setq listSpline (ssget '((100 . "AcDbSpline"))))
	(setq count 0)
	(repeat (sslength listSpline)
		(setq aob (vlax-ename->vla-object(ssname listSpline count)))
		(setq alay (vla-get-layer aob))
		(setq lpoints (vlax-safearray->list(vlax-variant-value(vla-get-controlpoints aob))))
		(setq nbp (length lPoints))
		(setq 	p1 (list 	10
							(nth 0 lPoints)
							(nth 1 lPoints)
							0.0)
				p2 (list	11
							(nth (- nbp 3) lPoints)
							(nth (- nbp 2) lPoints)
							0.0
		(makeLine p1 p2 alay)
		(setq count(1+ count))
	(setvar "cmdecho" 0)
	(command "erase" listSpline "")
	(setvar "cmdecho" 1)
	;reset
	(setq count 0)
		(vla-put-visible aob -1)
	(princ)
