Inventor Forum
Inventor 2013 Custom Materials Library Creation
5 REPLIES 5
chrishutchinson6848
1793 Views, 5 Replies
Is there a good source of material mechanical properties on the internet?  I have been creating a custom material library with the materials I normally use and I've just been duplicating a material from the supplied libraries to create mine with a name change only.  I'd like to include the correct mechanical properties if I could find a source of information that has all the properties in the format that the Inventor 2013 materials editor requires.
Chris Hutchinson
5 REPLIES 5
Hi chrishutchinson6900,
Here is one source:
http://www.matweb.com/
I hope this helps.
Curtis
mcgyvr
in reply to: Curtis_Waguespack
matweb is the best I've found.. I use it all the time.. Be prepared to do some annoying math to get the correct units for Inventor.
I wish Inventor had more of a dropdown next to each value allowing you to enter any of the common unit formats and it would do the conversion for you..
Ray_Feiler
in reply to: mcgyvr
I use convert.exe
http://wscope.com/convert.htm
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
mrattray
in reply to: Ray_Feiler
I typicaly just use google. It's quite capable for most common math and conversions. I downloaded you converter though, it looks useful.
Mike (not Matt) Rattray
in reply to: mcgyvr
For that purpose, you can change units for whole material library, then edit it, and change units back. You can do that in material library bottom left options.
