Is it possible to create projection views of a solid model part? I want to make a front, top and right side view of the part in solid model form all on the same part file. I thought I could copy the part in each view but "help" says I can't copy a solid model...
If what you want is to display multiple views of a part at the same time in an ipt file, I don't think there is any way I know of to do that. You would have to create a drawing and do it there.
Almost sounds like you want to create a drawing with all the related views.
Have you ever created an idw file in Inventor?
