Inventor Forum
Inventor 2013 crashes when using multiple functions
11 REPLIES 11
Message 1 of 12
roboconnell2004
834 Views, 11 Replies
I have been using this software for a few months now, and I continue to have crashing issues. The issues, however related, are not consistent. I tend to have issues when using more complex applications of the software such as crashes when performing a breakout view, freezing and then many times crashing when manipulating a part within an assembly drawing, and several other similar issues. I have received an update SP1.1 (176) and installed it. This update states it contains a fix for issues of crashing due to excessive memory consumption.This seems to be my issue, however I have 6GB of RAM, nVidia Quadro FX 3800 1GB graphics card, Intel Core i7 920 2.66GHz processor, and updated drivers...
I am looking for suggestions from someone who has had similar issues and was able to fix them, or from someone with the knowledge to assist in suggesting possible fixes. (I also have the company IT Guy looking into the issue, but he is unfamiliar with Autodesk and many of the issues related with Autodesk)
Thanks in advance!!!
11 REPLIES 11
Message 2 of 12
mrattray
in reply to: roboconnell2004
Those PC specs aren't very good for Inventor. What kind of work are you doing?
I struggle with memory consumption sometimes with 8GB, and I don't think my files are large at all. Also, your i7 is a complete waste for CAD work. Besides a couple of exceptions, most notably drawing views, Inventor only uses one core. That means as far as Inventor is concerned you have one 0.443 GHZ (2.66 GHZ divided by 6 cores) processor.
Mike (not Matt) Rattray
Message 3 of 12
roboconnell2004
in reply to: mrattray
I work for a manufacturing company that produces dryer systems, and we are currently transitioning into 3D. Mainly drums with inner flighting and seal plates ect... I am feeling that I am sitting in front of a machine that was quite nice 5 yrs ago, however I am told (from IT and Admin. ) that it spec.'s just great for AutoCAD. (although I am using Inventor) I feel that I am going to continue to have the issues as I am not scheduled for an upgrade for some time. I am looking for some type of suggestion for the time being. I understand that there are some issues with drivers and other typs of software that could keep performance to a crawl.
If you were going to order a new PC what specs would you insist on? I ask this so that I have some understanding of what is going to be good enough going into a meeting with IT about a possible upgrade...
Once again thanks in advance for your advice.
Message 4 of 12
nannerdw
No, the clock speed will still be 2.66 GHz, but it will just utilize one core (equivalent to a 2.66 GHz single core processor).
Message 5 of 12
mrattray
in reply to: nannerdw
I've been itching to use this Smiley Happy:
http://lmgtfy.com/?q=clock+speed+of+multi+core+processors
Message 6 of 12
nannerdw
Please provide a link which explains the behavior you're describing for multi-core processors.  It goes against everything I've ever read on the subject.
Message 7 of 12
dgorsman
Your hardware isn't *that* bad, aside from the RAM.  Might be a bit pokey here and there but with some additional RAM and good modeling practices it should be useable on moderately complex work for another few years.  RAM is relatively cheap so you might be able to bargain with your budget people to get more in exchange for holding off on requesting major hardware upgrades for a couple of years.
Message 8 of 12
mrattray
It looks like I spoke too soon and made myself look like an ****. Sorry. This is what usually happens when I pretend to be a tech geek. Smiley Embarassed
Message 9 of 12
blair
How often do you "Save" while working?
I also find that Inventor's stability is also related to a proper installation and a clean system.
1.) Logged in with Admin privileges when installing the software
2.) UAC slider set to lowest setting when installing the software
3.) I usually disable the Anti-Virus software when installing Inventor
4.) Having minimum of Power User setting while using the software
5.) Hard-drive is defragmented on a regular basis
6.) All temp directories and caches are purged and cleaned on a regular basis
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 10 of 12
JDMather
Are you using Projects (*.ipj) or Vault?
Modeling techniques can effect the behaviors you describe.
Assembly constraints can effect the behaviors you describe.
You want to develop the strong robust modeling/assembly constraint techniques.
Read response #8 by Walt Jaquith in this thread http://forums.autodesk.com/t5/Autodesk-Inventor/IS-INVENTOR-REALLY-USEFUL/m-p/1332811/highlight/true...
Hardware and other software on machine can effect the behaviors you describe.
These can be the most difficult problems to solve.  Especially for an older machine.
I recommend restoring a HDD to out-of-the-box OS condition and re-install of software every 1-2 years.
In my experience I am always shocked how "renewed" my machine seems after going through this tedious process.
I have run fairly satisfactory on some very old (32-bit) OS machines.
Of course if you can get a new machine.....
Message 11 of 12
SBix26
You haven't told us what operating system you're using.  I assume Windows 7 64-bit.  If not, we've found a big part of the problem.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 12 of 12
Hi! When it crashes, did you submit crash report? If yes, could you send me an email with the email address you submitted the report with? If not, please submit crash report with your email address and send me a private email at (johnson.shiue@autodesk.com).
Have you tried turning the following option off?
Go to Tools -> Application Options -> Drawing -> uncheck "Enable Background Update"
Thanks!
Software Test Engineer
