Inventor General Discussion
Member
onebadcad
Message 1 of 2 (200 Views)
Inventor 2013 apperence colors
200 Views, 1 Replies
12-13-2012 11:17 AM
None of the material colors that inventor 2013 actually look like what they say. White in gray, any polished stainless also a gray color. Is it posible to copy the styles library from 2009 into 2013?
*Pro
sbixler
Message 2 of 2 (174 Views)
Re: Inventor 2013 apperence colors
12-18-2012 05:14 AM in reply to: onebadcad
Try modifying your lighting style.  The default lighting style is Two Lights, and one of these lights is set to a bluish gray color.  Change the color to white-- gray becomes white again!  You might also bump up the Ambience setting under All Standard Lights while you're at it.
