Inventor General Discussion
Active Member
bmevans
Message 1 of 15 (250 Views)
Inventor 2013 Animation Question
250 Views, 14 Replies
10-02-2013 08:00 AM
Need some advice on how to animate both propellers of a plane at the same time.  I can animate one but not both.  Any advice would be appreciated.
*Expert Elite*
JDMather
Message 2 of 15 (243 Views)
Re: Inventor 2013 Animation Question
10-02-2013 08:27 AM in reply to: bmevans
What environment?
Assembly?
Inventor Studio?
Dynamic Simulation?
Make a named parameter and the Drive Angle Constraint using the samed named parameter for both (if counter-rotating use -named parameter for one).
Attach your assembly here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
bmevans
Message 3 of 15 (209 Views)
10-04-2013 10:11 AM in reply to: JDMather
Couldn't get it to work. Thanks for your help!
*Expert Elite*
JDMather
Message 4 of 15 (206 Views)
10-04-2013 10:17 AM in reply to: bmevans
If you couldn't get it to work - how was I of any help?
Attach your assembly (or a simplified mock-up) here.
I'm sure there is an easy solution.
Active Member
bmevans
Message 5 of 15 (206 Views)
10-04-2013 10:20 AM in reply to: JDMather
I sent it to you earlier.
*Expert Elite*
JDMather
Message 6 of 15 (200 Views)
10-04-2013 11:00 AM in reply to: bmevans
I don't know what that means?
To my email?
If so, did I respond back?
Are you replying to threads by email reply?
You need to go the web interface to add file attachments.
Active Member
bmevans
Message 7 of 15 (191 Views)
10-04-2013 01:03 PM in reply to: JDMather
I responded to your first message to me.
*Expert Elite*
JDMather
Message 8 of 15 (184 Views)
10-04-2013 01:59 PM in reply to: bmevans
What does that mean?  (this is a multiple choice question)
Did you attach your assembly here?
Do you see your assembly attached here?
What environment are you attempting this animation? (this is a multiple choice question)
Assembly?
Inventor Studio?
Dynamic Simulation?
Can you attach your assembly here? (this is a Yes/No question)
I am sure there is a simple solution to your animation problem - but more information is needed in order to provide this solution.
Active Member
bmevans
Message 9 of 15 (178 Views)
10-04-2013 07:54 PM in reply to: JDMather
I'm sorry! I attached it twice but I guess you are not receiving it.
Sent from my iPad
*Expert Elite*
JDMather
Message 10 of 15 (171 Views)
10-05-2013 03:33 AM in reply to: bmevans
You should always confirm after attaching files that they are in fact available.
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Announcements
Need installation help?
