My Content Center is empty. I'm a Vault user on a network. I recently upgraded from 2010 to 2012 and now there is no content in the Content Center. What happened?
Hi mrm01,
Is there no any Content Center file or just happend to customized libraries? Can you check if the Content Center libraries are presented in Vault Server Console 2012?
Nicolas
Are you setup for the local content center (Inventor Desktop Content) or from a Vault server? Go to "Application Options" > "Content Center" tab. See if your "Access options" match the intended setup, try switching the selection. If you intended local content and that was selected, you may have to install the libraries. I'm not certain, but I think you can go back into the install setup and add them there.
-Brian
