I need help using the Arbor Press Tutorial. I have downloaded the tutorial file and the offline help file and installed both of them properly. I was wondering how you get a step by step walkthrough of the tutorial, like in the older versions. I was also wondering if anyone knows how to take the involute gear tooth profile off a gear designed in the desing accelerator and use it to create the matching pinion? I noticed in the arbor press model that while it has a pinion, the tooth profile is not an involute profile. Thanks for your help.
Step-by-step walkthrough of what tutorial? Inventor Studio?
You will have to answer questions to carry on a discussion.
hey did you ever manage to get it working?.... im using 2014 and been trying for days to get this tutorial for a project
Are you just trying to get the Arbor Press files that are used in tutorials, or are you trying to get the Inventor Studio Tutorials that use these files (same question the OP didn't answer 3 yrs ago)?
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-FBCDDF07-41E2-4B6F-9E05-56C5447AE644
