having trouble creating dimples using punch I created in the 0.005" sheet metal. the punch is 90° to the plate? can anybody help?
Seems like this has been covered here very recently?
The key to a Punch feature like this is to get a workplane perpendicular to the placement plane.
The way I start out is with a sketch circle placed at a sketch point (the first sketch has to have the sketch point.
Then I create a line bisecting the circle.
Add a coincident constraint at the midpoint to the sketch point.
Exit sketch.
Now you have the needed geometry to create the perpendicular workplane - simply click the sketch point and the sketch line.
Use that dependent child workplane to create all geometry for the Punch tool.
I'll try to post an example on Monday - meantime a search back a week or three should turn up links to a tutorial (I think by Curtis, I do mine slightly different).
I want to emphasize - only the first sketch of the Punch should be on the face of the part - all other geometry should be totally dependent on this first sketch rather than dependent on the part face for really robust punch tools. That way when placing - there is only one placement reference (other than the sketch centerpoint) the face of the part. When authoring if it indicates multiple references will be needed - there might be a better way to create the punch.
Here is a start -
Note: if you have AutoProject Origin turned on (you should) - delete the projected origin as you don't want that in a punch sketch.
Note: that the line in the circle does not have a horizontal or vertical constraint and that the Workplane is only dependent on the sketch line and the sketch point - it is not dependent on any other part geometry.
I have tired to create the shape I require but cannot create a punch feature from it, please see attached. I am doing somthing wrong, please advise. I have seen the tutorial on sheet metal by Daryl Corelli but his punches are for louvers.
