Hi there:
I'm having a issue with Autodesk Inventor 2012 running on Windows 7, what can I do to solve this? Do I need to perform a clean install? Thanks un advance.
Try creating a new assembly file, and insert any part from the content center..
If an error windows appears, I believe that this is because you didnt installed the content center of Inventor.
If you go to add/unistall programs in windows 7, you should be able to see the "Autodesk Inventor Content Center library¨¨
