Inventor General Discussion
Distinguished Contributor
0 Kudos
Post 1 of 3
Inventor 2012 Pro - flat pattern for a solid
444 Views, 2 Replies
11-09-2012 01:58 PM
Is there a way, in an .idw (drawing file) to create a flat view (unrolled) of a cylindrical solid? NOT to be confused with sheet metal. This is from a solid .ipt. Either that or create a flat pattern of a solid cylinder that IS NOT SHEET METAL?
244 Kudos
Post 2 of 3
Re: Inventor 2012 Pro - flat pattern for a solid
11-09-2012 07:40 PM in reply to: jrm_1971
ok well not too sure if this still falls within your allowable methodology, but maybe if you want to, you could derive the cylinder into a new sheet metal part, ipt (choose import as a surface). Then just thicken the outer skin, rip it and flatten it.
when you save the file, just call it the same file name as the main part but add a postfix to the name to indicate that it is related information.
best regards,
- Mark
(Kudo or Tag if Solved - it may help others)
PDSU 2015 Windows 8.1, 64bit.
2,124 Kudos
Post 3 of 3
11-10-2012 05:40 AM in reply to: jrm_1971
Sheet metal is just a term for a catagory of specialized tools.
Attach your file here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
