HELLO EVERYBODY!
I am an engineering Spanish student who wants to learn Inventor 2012. I just need it to practice with small parts and simple assemblies. My problem is that my computer can't handle this software. I am looking for a cheap PC (up to 300€) in order to install Inventor 2012. I have seen the following:
I'm a little desperate, I have asked in a couple of shops and they told me that I need a 600€ worth PC!!
Thank you very much for your help!!
Xabi
Solved by JDMather. Go to Solution.
Solved by mcgyvr. Go to Solution.
Solved by blair. Go to Solution.
What is your computer specs of the one you have?
I'd suspect it can probably work just fine with Inventor.
I've run it on some very cheap computers before.. For just simple stuff it "should" work..
Download/try it out
Just look for a good fast "Gaming" PC, stick with Windows7 64 bit, at least 6Gb of memory, fastest clock speed processor you can afford and a fast "Gaming" graphics card.
I have already tried this version and when i want to draw the screen turns white and i can not work anymore.
The specs are the following showed in this link:
http://www.lg.com/hk_en/notebooks/lg-R310-K
Thank you very much!
I have almost no idea about computers...
How much should it cost? Do you recommend me some in particular?
Thank you so much!
Try it again..This time go to ..tools..application options...hardware tab and set it to "software graphics" or whatever the lowest setting is.
Try going to Tools>Application Options>Hardware tab and set to Software Graphics. Does it work now?
Have you installed all Service Packs?
Oops, I'm too late. What happened to our Delete button?
Guess it might fall into the ......"some of the previous site functionality that was inadvertently removed"
