Inventor General Discussion
Member
SteveOlson
Message 1 of 10 (320 Views)
Inventor 2012 model shading/colour Issues
320 Views, 9 Replies
02-07-2014 08:40 PM
I am a student in grade 12 and I am using inventor 2012 for a project.  I have followed a tutorial on youtube on how to make a rim for a car (seen here http://youtu.be/-rCZNFARSfQ )
When i completed my drawing i noticed that the curved inner wall of the outer part of the rim had lines and did not go away in the rendering.
I think it would be cool I could design my own set of rims, but i could not bring myself to hand in something that does not look perfect.  I do not know if there are any settings to get rid of the lines or if you have to render the image in something like autodesk showcase?
Steve
Cadmanto
Message 2 of 10 (294 Views)
Re: Inventor 2012 model shading/colour Issues
02-08-2014 05:52 AM in reply to: SteveOlson
Hi Steve,
Welcome to the forum.
In your drawing are you using a shaded view? or what representation are you using?  You have a couple of options.  If there are only a few lines you can select them and RC and hide them.  Or you can RC on the view itself and edit it and under the display tab are some settings that could work for you as well.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
JDMather
Message 3 of 10 (290 Views)
02-08-2014 06:09 AM in reply to: SteveOlson
Can you roll up the EOP and attach the file here?
Do you have a Surface Body visible that you forgot to turn off?
If not that, I suspect a lighting change will take care of the problem, but my first bet is a surface body overtop the solid faces.
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
SteveOlson
Message 4 of 10 (266 Views)
02-09-2014 12:47 AM in reply to: JDMather
here is the file, I hope i "packaged" it right!
Member
SteveOlson
Message 5 of 10 (265 Views)
02-09-2014 12:47 AM in reply to: Cadmanto
Hey Cadmanto,
i was using the shaded veiw but the lines appear in other views also.  They are not actual lines that i can click on but lighting errors(?) that change when you zoom in.
JDMather
Message 6 of 10 (249 Views)
02-09-2014 06:30 AM in reply to: JDMather
..... but my first bet is a surface body overtop the solid faces.
Find the Surface Body in the feature browser and right click on it and turn off Visibility.
Cadmanto
Message 7 of 10 (239 Views)
02-09-2014 08:36 AM in reply to: SteveOlson
Steve,
I like JD, was thinking the same thing.  I called your part up and was wondering the exact same thing.  I didn't see any lines, but saw you had the surfaces turned on.  Not to mention I got the impression that this was happening in a drawing.
Best Regards,
Scott McFadden
JDMather
Message 8 of 10 (234 Views)
02-09-2014 09:04 AM in reply to: Cadmanto
Cadmanto wrote:
 I didn't see any lines,...
There were a couple of Suppressed features at the bottom of the tree, when I unsuppressed the Combine feature the "lines" became apparent.
Cadmanto
Message 9 of 10 (230 Views)
02-09-2014 09:19 AM in reply to: JDMather
I didn't do that.  I undid the roll back and didn't see anything was where I was coming from.
DIdn't have time to dig into it that deeply.
Best Regards,
Scott McFadden
Member
SteveOlson
Message 10 of 10 (184 Views)
02-11-2014 10:10 AM in reply to: JDMather
Thanks for showing me!  Looks way better!
