Inventor General Discussion
Valued Contributor
machiel.veldkamp
Message 1 of 9 (878 Views)
Inventor 2012 freezes on almost everything.
878 Views, 8 Replies
10-11-2012 02:21 AM
PROBLEM: Whenever I draw aline, make a constraint, try an extrude; inventor hangs / freezes for 1-30 seconds before executing the command.
SPECS:
RAM: 16GB DDR3
CPU: Intel Xeon W3690 @3.47Ghz (multitreading so basiccaly 16 cores)
Video: NVidia Quardo 2000 (1GB dedicated ram and 4 GB shared)
Explaination.
I work in a large company where everyone works with Inventor and everyone has this problem but now I'm sick and tired of it and I want to know WHY this is happening. I will explain:
We work with so called mastersketches, for whom may not know this concept is is the use of a single ipt with all sketches of a/some components in them so they are linked and constrained in that one file. It is a very light and fast methode for large assembly's
I am working on a mastersketch with about 20-30 sketches in them and when I want to use some sketes in a other part (derived) inventor tends to hang on almost every execution for a couple of seconds.
This is very anoying and time consuming.
It doesn't matter if I work locally, in the vault or on a network disk, it happens all the time and it pisse me off.
Does anyone recognise this and perhaps has a solution? I tried a lot but nothing seems to work (all settings are optimal and as low as possible)
With kind regards,
Machiel Veldkamp
The Netherlands
___________________________
Inventor 2012 lastest service pack
RAM: 24GB DDR3 / CPU: Intel Xeon W3690 @3.47Ghz
Video: NVidia GeForce 680/ HDD: 15.7K
Windows 7 Pro 64-bit
Ok so this was the real problem:
our main server is located in Sweden (3000 km from here(1100 miles?)) and the mastersketch (skeleton) which was derivede in a component had to be calculated everytime I added something to my extrusion so bassically.
I downloaded the whole project on my C: drive and all the problems i had before are gone.
Protip!: DON'T USE NOT-LOCALLY BASED SERVERS
When your in a situation that you're forced to work on a server, always check WHERE that server is based.
I had experience with servers which were based in the same building with a fast connection but yeah this sucked.
So thanks for all your replies, it's cool now.
Distinguished Contributor
richiesuk
Message 2 of 9 (866 Views)
Re: Inventor 2012 freezes on almost everything.
10-11-2012 03:02 AM in reply to: machiel.veldkamp
my workmate had the same issue, and the project fil was set up badly.
(material library was o nthe server it worked for me but not for him...)
Valued Contributor
machiel.veldkamp
Message 3 of 9 (859 Views)
thats not it. All material libs are on the C drive. I...
10-11-2012 03:17 AM in reply to: richiesuk
I also have this problem if files are located in my spare-time project which is also located (of course) on the C-drive with all content and everything on the (you guessed it) C drive.
One thing it may be is the hard drive itself. It may be a 4200RPM drive but I don't know how to check that on windows 7.
EDIT: it's a 15K rpm drive
JDMather
Message 4 of 9 (843 Views)
Re: thats not it. All material libs are on the C drive. I...
10-11-2012 07:07 AM in reply to: machiel.veldkamp
Can you attach file(s) here that exhibit this behavior?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
machiel.veldkamp
Message 5 of 9 (783 Views)
10-16-2012 12:11 AM in reply to: machiel.veldkamp
No I cannot. It's company property and if I share it, then I am in violation.
Valued Contributor
machiel.veldkamp
Message 6 of 9 (776 Views)
10-16-2012 03:03 AM in reply to: machiel.veldkamp
Note: I noticed inventor hangs on calculating the area's on a sketch the longest. (a minute or so)
this is true in case of an extrusion (edit or new doesn't matter)
Valued Contributor
nannerdw
Message 7 of 9 (764 Views)
10-16-2012 04:08 AM in reply to: machiel.veldkamp
What virus software are you using?  Check task manager to see if any processes other than Inventor are causing CPU spikes during or imediately after the program freezes.  This happens to me whenver McAfee is running a virus scan.
-Using Autodesk Inventor Professional 2012
Valued Contributor
machiel.veldkamp
Message 8 of 9 (745 Views)
10-16-2012 05:57 AM in reply to: nannerdw
Really, it can't be the cpu. I have a fudging horse on the table here. I have the task manager open almost all the time and the CPU load never hits 20%
Sometimes on one of the 16 cores 100% for a few miliseconds but not really anything else.
I checked a LOT of things. I checked CPU load, where the ram goes. I checked the SMART status of the HDD, I checked the logbook of windows (yeah here and there a few nothing saying warnings)
But really, I have NO clue what the F is going on.
Valued Contributor
machiel.veldkamp
Message 9 of 9 (718 Views)
I have found a solution
10-17-2012 01:58 AM in reply to: machiel.veldkamp
