Inventor Forum
Inventor 2012 - Export to PDF - Quality is Terrible
14 REPLIES 14
Message 1 of 15
cascadety
6201 Views, 14 Replies
Is it possible to increase the quality of exported pdf's from Inventor 2012?  Anything with a metalic (ie. black chrome) finish as a pdf looks terrible when compared to what is shown on screen.
14 REPLIES 14
Message 2 of 15
cascadety
in reply to: cascadety
Really?? No experts on boad that know a procedure to increase the quality of pdf's created using the "export" function from Inventor 2012?
Let me clarify:
On screen part/assembly/drawing quality - Excellent
Print quality - Excellent
PDF quality - Marginal (as in bitmap / low-res)
Any Ideas?
Message 3 of 15
mpatchus
Maybe an example of what you are seeing would help.
I've gotten reasonable results of PDF exports (see attached)
Not nearly as good as rendered images, but decent enough to use in-house.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 4 of 15
cascadety
in reply to: mpatchus
Hey,
Thanks for the response and suggestion.  Your pdf seems to have much better clarity than any I create using the export command.  See attached example "mesh.pdf" file.
Our company uses BlueBleam pdf creator for the majority of our pdfs.  However, it only intergrates with AutoCAD and not Inventor.  Using BlueBeam as a printer in Inventor produces worse results than exporting.  See attached "mesh BB.pdf" file .
Additionally, the goal for these pdf's is to use out-of-house.
Message 5 of 15
Ryan.Martinez
Did you try changing the vector resolution in the export options?
P.D.S. 2015
P.D.S. 2016
Message 6 of 15
blair
in reply to: Ryan.Martinez
Did you increase the DPI resolution when using the Export to PDF (in the Options when doing the export).
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 7 of 15
cascadety
in reply to: blair
Thanks for the responses.  Increased the resoluion to 4800 and it did help some.  It appears to be the nature of the coil spring mesh in the black chrome surface tho.  Parts in other finishes look much better.
Thanks again
Message 8 of 15
elixin77
My company uses CutePDF writer, and it works for what we do.  Whenever I print something that has a perforated or checker plate material applied to it, it comes out just fine.
Message 9 of 15
mpatchus
We have stopped using print add-ons to create the PDFs.  We've found exporting the file as a PDF produces better results than "printing" as a PDF.
Inventor 2025 Beta
Message 10 of 15
elixin77
Oh my, I did not realize how nice the export to PDF option is.  Blueprint quality is very much improved.
I'll be using the export feature from now on - thank you!
Message 11 of 15
Emil.Lewandowski
in reply to: elixin77
When exporting to PDF from iam or ipt I can't change options in the export to PDF window.
Nothing happens when clicking the options.. button.
When exporting from dwg/idw it works fine. Anyone else having this problem?
/Emil
Message 12 of 15
mpatchus
in reply to: Emil.Lewandowski
I don't think the options are enabled for anything but the IDW/DWG mode.
Inventor 2025 Beta
Message 13 of 15
blair
Correct, if you are in the modeling enviroment, you don't have any Export PDF options. You would be better to use the Export to graphics and select either the BMP, JPG or PNG options. You will have options/settings there.
Delta Tau Chi ΔΤΧ
Message 14 of 15
PhilSaw
in reply to: blair
In 2012 you can export a model environment image to PDF?
Please click "Accept as Solution" if this response answers your question.
Autodesk Inventor Professional 2012
Windows 7 Professional, 64-bit (Service Pack 1)
Intel(R) Core(TM i7-2600 CPU, Quadro 2000 graphics card, 8G RAM
Message 15 of 15
PhilSaw
in reply to: PhilSaw
Oops, mis-read the post about "options" Smiley Embarassed
