Hello all,
-I am creating a drawing template in Inventor 2012 and have different line weights for different features in the drawing. Is there a way to keep those line weights different, but have the printer print a single line weight?
-Additionally, when creating a border for the sheet the origin of the sheet is always placed in the bottom left corner of the manilla/yellow sheet. I can dimension my border a distance from the sheet edges. Is there a way to move the origin to a specified location?
Thanks for the help
Candace
Solved by mcgyvr. Go to Solution.
@babijay43 wrote:
Hello all,
Thanks for the help
Candace
In the print dialog there is a checkbox to "remove object line weights"
Not sure about the border.. I just used the out of the box border and haven't messed with drawing templates in years.. But I did create my own titleblock..
@babijay43 wrote:
... Is there a way to move the origin to a specified location?
Candace
Attach your file here so that someone can take a look.
Thanks for the reply. I've found the "Remove Line Weight" option in the printer dialog box, but wanted to know if there was a way to set the uniform line weight before printing. Is there a way to do that without this property being applied to all documents printed outside of Inventor?
Attached is a screenshot of the border being edited where you can see the sheet origin in the bottom left corner. I need to move it 1/4" in and up from its current location because when I import a drawing from an AutoCAD/Mechanical Desktop file the border snaps to the inventor corner instead of centering on the sheet. A sample file is also attached. Does anyone have an idea of how to either move the inventor sheet origin or have imported borders automatically center on the Inventor sheet?
Candace
Just set them up all the same line weights and don't worry about it..
If you are always turning them off for printing then don't even set them up..
The intent of line weights is to make it easier for someone interpreting the drawing to differentiate between lines when reading a printed drawing or pdf of it..
Its not really to aid the drafter who is creating the drawing (but it can help I guess)
I'm not aware of another way to force removing line weights other than at printing time..
Thanks for the help with my last post. Is anyone familiar with the Inventor 2012 import capabilities? If so, I am looking for some help with figuring out:
-How to get windows file properties to import into iproperties? I've imported CAD files with Windows Summary info entered (such as the Title) of the file, but when I open the imported part file in Inventor its 'Title' field remains blank. Does anyone have an idea of where the file properties information is stored after import?
-How to get Inventor to import all drawing files associated with parts and subassemblies within an imported assembly file? When I import the main assembly, all subassemblies and parts are imported from AutoCAD/Mechanical Desktop. However only the drawings for the subassemblies of the main file are created (excluding drawings tied to parts within the subassemblies). My config setup is attached. Do you have any advice on how to remedy this without having to use the task scheduler to import each file associated with my main assembly?
Thanks again for the help,
Candace
