i am using inventor2012 and have a problem with frames;
when i create a frame with Insert Frame, it places the frame as a part
(Frame0001/ ISO 657-1 - L40x40x4-400) in browser, it is ok.
and then i use Patternt tool, it creates a part
(Component Pattern/ Element:1/ Frame0001/ ISO L40x40x4 00000001:1) in browser. it is ok.
but when i used Insert Frame to crate new frame, the second frame part places in
Component Pattern/ Element:1/ Frame0001/ ISO 80x40x6 00000002:1
and same pattern setting is applied on new frame part too, but i do not want apply pattern (or not same pattern) on new frame. and all frames (patterned frames too) hold together by Component Pattern part.
how can i place new frame separated with first frame.
if it is necessary, i upload a few screenshot or video.
thanks for help already.
Screen shots or video would be very helpful to see exactly what you are doing. Need to see or know more about your workflow. Have you had any training or run any tutorials on Frame Generator?
AutoCAD 2013; AuoCAD Electrical 2013; IV 2013 Professional: Tube and Pipe, Frame Generator, Content Center; Vault Professional 2013: Client, ECO
Win 7 x64, Dell Precision T7500, Intel(R) Xeon(R) CPU X5677@3.47GHz, 12 GB RAM; GeForce GTX580; 3DConnexion Space Explorer, Evoluent Vertical Mouse 3.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
this is a simple, but this happens every time
sorry about resolution, i forgot to set it up, but i suppose you can see what i tried to do;
i inserted frame1 (rectangle),
then i inserted frame2 (L equal legs) (even tough i did not want to place with frame1, it did),
then i used pattern tool on one of frames (it choosed both), frames patterned,
i inserted frame3 (T profile)
(you saw; even tough i did not want to place frame3 with frame1 and frame2, it did.
and even tough i did not want to apply pattern on frame3, it did)
if you are not able to see whats going on video, then i can grab a new one or maybe screenshots will better.
Cannot view the video. Try some screen shots, preferably ones that incluse the model tree so I can see the structure of your assemblies.
Chris Benner
this forum supports only 3 images per message, so i uploaded them on my google+
