Inventor General Discussion
63 Kudos
Post 11 of 37
Re: Inventor 2012 Crash Problems
05-27-2011 06:26 AM in reply to: kschumacher
When crashing while changing view settings within an Inventor drawing (IDW) process, try this:
Options-Drawing Tab-Capacity/Performance section-Memory Saving Mode Check box - TURN IT OFF.
jvj
jvj
New Member
0 Kudos
Post 12 of 37
05-30-2011 10:17 PM in reply to: kschumacher
hi, i'm having the same problem whith inventor 2012, last week it crashed every day 10+ times per day, i see  if I enable the "Enable background updates" Option in the application options Inventor crashes everytime I try to make a new custom view. Regardless of how complicated the part is. Once I turned off this feature it was better, but now, i finish my drawing and when i try to save the drawing it crashes, or when i try to export to autocad dwg file it crashes too, and then no way to save my drawing again, i can open but if i make some changes on it, and if y try to save, or save as, it crashes!!
please some help!!
i'm a formwork conceptor, and i have a lot of work at this moment, i can't waste my time like this...
Mota
HP Z400 workstation
Intel(R) Xeon(R) CPU W3565 @3.20GHz 3.19GHz
Windows 7 Professional 64 bits
12GB RAM
NVIDIA QUADRO 4000 2GB
Drivers 265.70 [8.17.12.6570]
Monitor HP ZR24w
New Member
1 Kudo
Post 13 of 37
06-11-2011 03:55 AM in reply to: kschumacher
had a look at my setup, many crashes.. many many crashes.. Looked at graphics setup , set at software, changed , and working a lot better. Thanks. also turned off background updates in drawing settings. so must be one of these my guess is the software setting on the graphics.
New Member
0 Kudos
Post 14 of 37
08-03-2011 07:06 PM in reply to: JamieVJohnson2
Turning off background updates worked for us.
Thanks guys this was driving us crazy!
Employee
6 Kudos
Post 15 of 37
08-03-2011 11:29 PM in reply to: tony.browne
We released a hotfix for this issue sometime back to fix some of the instabilities in drawing view updates.
Once the hotfix is applied - its no longer necessary to turn OFF enable background updates and is safe to use.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si​teID=123112&id=17235749&linkID=9242019
We apologize for the inconvenience caused.
-Shiva Sundaram
Inventor Development
0 Kudos
Post 16 of 37
08-04-2011 05:23 AM in reply to: Shiva_Sundaram
The Page You Requested Was Not Found
Employee
6 Kudos
Post 17 of 37
08-04-2011 07:30 AM in reply to: kschumacher
My apologies. Not sure what happened with the cut-n-paste.
Here is the correct link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17235749&linkID=9242019
New Member
0 Kudos
Post 18 of 37
10-05-2011 03:01 PM in reply to: Breemum
After trying to apply the HotFix, a prompt ask me to instert the AutoDesk Disk containing the Inventor.msi.
I placed the USB containing our Design Suite Premier 2012 and target either the E:\x86\ or E:\x64\Inventor\Inventor.msi and receive this error.
Internal Error 2902. ixfAssemblyCopy
Employee
6 Kudos
Post 19 of 37
10-05-2011 03:08 PM in reply to: SMitchellHME
Have you already applied Inventor 2012 SP1 - if so, this hotfix is not necessary as its already included as part of Inventor 2012 SP1.
-Shiva Sundaram
Active Member
0 Kudos
Post 20 of 37
10-26-2011 05:49 AM in reply to: JamieVJohnson2
In that case (SP1 includes this hotfix), then the hotfix is worthless.  I have SP1 installed and Inventor still displays this behavior: especially on large models!!
