Inventor General Discussion
JamieVJohnson2
Message 11 of 37 (2,384 Views)
Re: Inventor 2012 Crash Problems
05-27-2011 06:26 AM in reply to: kschumacher
When crashing while changing view settings within an Inventor drawing (IDW) process, try this:
Options-Drawing Tab-Capacity/Performance section-Memory Saving Mode Check box - TURN IT OFF.
jvj
jvj
New Member
Coffrage&quipage
Message 12 of 37 (2,344 Views)
05-30-2011 10:17 PM in reply to: kschumacher
hi, i'm having the same problem whith inventor 2012, last week it crashed every day 10+ times per day, i see  if I enable the "Enable background updates" Option in the application options Inventor crashes everytime I try to make a new custom view. Regardless of how complicated the part is. Once I turned off this feature it was better, but now, i finish my drawing and when i try to save the drawing it crashes, or when i try to export to autocad dwg file it crashes too, and then no way to save my drawing again, i can open but if i make some changes on it, and if y try to save, or save as, it crashes!!
please some help!!
i'm a formwork conceptor, and i have a lot of work at this moment, i can't waste my time like this...
Mota
HP Z400 workstation
Intel(R) Xeon(R) CPU W3565 @3.20GHz 3.19GHz
Windows 7 Professional 64 bits
12GB RAM
NVIDIA QUADRO 4000 2GB
Drivers 265.70 [8.17.12.6570]
Monitor HP ZR24w
New Member
s.hemmingsen
Message 13 of 37 (2,249 Views)
06-11-2011 03:55 AM in reply to: kschumacher
had a look at my setup, many crashes.. many many crashes.. Looked at graphics setup , set at software, changed , and working a lot better. Thanks. also turned off background updates in drawing settings. so must be one of these my guess is the software setting on the graphics.
New Member
tony.browne
Message 14 of 37 (1,967 Views)
08-03-2011 07:06 PM in reply to: JamieVJohnson2
Turning off background updates worked for us.
Thanks guys this was driving us crazy!
Employee
Shiva_Sundaram
Message 15 of 37 (1,960 Views)
08-03-2011 11:29 PM in reply to: tony.browne
We released a hotfix for this issue sometime back to fix some of the instabilities in drawing view updates.
Once the hotfix is applied - its no longer necessary to turn OFF enable background updates and is safe to use.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si​teID=123112&id=17235749&linkID=9242019
We apologize for the inconvenience caused.
-Shiva Sundaram
Inventor Development
kschumacher
Message 16 of 37 (1,947 Views)
08-04-2011 05:23 AM in reply to: Shiva_Sundaram
The Page You Requested Was Not Found
Employee
Shiva_Sundaram
Message 17 of 37 (1,930 Views)
08-04-2011 07:30 AM in reply to: kschumacher
My apologies. Not sure what happened with the cut-n-paste.
Here is the correct link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17235749&linkID=9242019
New Member
SMitchellHME
Message 18 of 37 (1,676 Views)
10-05-2011 03:01 PM in reply to: Breemum
After trying to apply the HotFix, a prompt ask me to instert the AutoDesk Disk containing the Inventor.msi.
I placed the USB containing our Design Suite Premier 2012 and target either the E:\x86\ or E:\x64\Inventor\Inventor.msi and receive this error.
Internal Error 2902. ixfAssemblyCopy
Employee
Shiva_Sundaram
Message 19 of 37 (1,672 Views)
10-05-2011 03:08 PM in reply to: SMitchellHME
Have you already applied Inventor 2012 SP1 - if so, this hotfix is not necessary as its already included as part of Inventor 2012 SP1.
-Shiva Sundaram
Active Member
dpaskman
Message 20 of 37 (1,549 Views)
10-26-2011 05:49 AM in reply to: JamieVJohnson2
In that case (SP1 includes this hotfix), then the hotfix is worthless.  I have SP1 installed and Inventor still displays this behavior: especially on large models!!
