Can not Install hotfix DL17235749_64-bit. Intallation gives me:
Internal error 2902. ixfAssemblyCopy
and then,
Fatal error: Installation ended prematurely because of an error
Hi Denis,
Why you don't install the Inventor 2012 Service Pack 1 (2011-Aug-31)
The SP1 already contains all previous hotfixes
Inv 2012 Service Pack: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17534725&linkID=9242019
Hi Manuela
We have a much bigger problem opening some drawings in Inventor 2012 from Autodesk Productstrem Professional 2011 (PSP 2011).
Inventor crashes.
I have SP1 installed allready. - This didn't fixed the issue.
So I have tried to install that hotfix, because I susspected it was not included into SP1.
Thanks for your time and will to help!
(I will make a new thread on that matter=
Denis.
Hi DWEN,
Same problem you mean HotFix installation error?
I just gave up on this one.
regards,
Denis
Yes, I tried to instal DL17089522_64-bit. (= hotfix)
Every time error.
Also instaled a PC Health advisor (ParetoLogic PC)
Did not help. Onely cost a lot of money.
Greetings
DWEN
