Inventor Forum
Inventor 2012 - API
1 REPLY 1
282 Views, 1 Reply
Inventor 2012 - API
I can hide an occurrence by setting its visible property and update the active view. This is working fine only for the direct occurrence for the active document. But i want to hide a part occurrence that comes under one of the sub assembly. How to accomplish this?
1 REPLY 1
CCarreiras
Hi!
You have to change the filter:The filter in assembly enviroment is defined by default as "Select Priority Component" and therefore, Now you are selecting all sub-assembly as one "occurrence".
Change the selection filter to " Select Part Priority": This way you can select any parts placed in a sub-assembly directely from the main assembly...
... so:
  1. Change the filter (is easy, check the image below)
  2. Selectthe part
  3. Uncheck visibility as a normal main assembly part.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
