Inventor Forum
INVENTOR 2012 AND 2014
5 REPLIES 5
230 Views, 5 Replies
why investor 2012 doesnt work in my pc, i downloaded it into my pc and doesnt open and also i downloades 2014 and it keeps doing the same, my pc is a windows 8, can somebody help me please? "THE APPLICATION WAS UNABLE TO START CORRECTLY (0xc0000142). Click OK to close the application"
 tha is the message that i get , help me please!!!!!!!!
5 REPLIES 5
admaiora
Hi Lipe,
i suggest to use the 2014 release.
To make it works, you have just to install this service pack:
http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-in...
Let me know.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Paul-Mason
in reply to: admaiora
Edited @ 13.22 BST
Nether 2012,2013 or 2014 are directly compatible with Windows 8. to get them to work there's a lot or registry hacks needed They may be compatible with Windows 8.1. There have been numerous post on these boards about this here is a link to the 1000+ results
http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=Windows+8
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
admaiora
in reply to: Paul-Mason
Inventor 2014 is compatible with Windows 8  (64 bit).
http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
Admaiora
blair
Make sure that you have downloaded and installed all the SP's and Updates for your ADSK product.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
ChrisMitchell01
in reply to: blair
Every release of Inventor since 2011 now works on win8/8.1 but as mentioned below only if you apply the latest Service packs &/or updates.
No registry hacks are required, but you do need to run a manual dll registration command after installing the Service packs &/or updates.
For example for 2012, first see this
Then follow the steps as documented toward the bottom of this article.
Chris
Chris Mitchell
PDMS Customer Engagment Team
