Inventor General Discussion
Panygeric
Message 1 of 7 (1,400 Views)
Accepted Solution
Inventor 2012 - ACME Threads Not Available??
1400 Views, 6 Replies
04-19-2013 11:14 AM
Just a basic question I'm seeming to run into - Apparently "ACME"-style threads are not available in Inventor 2012??
Ray,
Fair enough.  I was just checking.
Then the short answer is "No".  You are going to have to create your own thread.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
*Expert Elite*
Cadmanto
Message 2 of 7 (1,383 Views)
Re: Inventor 2012 - ACME Threads Not Available??
04-19-2013 12:13 PM in reply to: Panygeric
Don't you mean ASME?  If so they coincide with ANSI which are there.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Valued Mentor
RayFeiler
Message 3 of 7 (1,379 Views)
04-19-2013 12:15 PM in reply to: Cadmanto
ACME
http://www.mcmaster.com/#about-acme-threads-for-threaded-rods/=me4obt
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
*Expert Elite*
Cadmanto
Message 4 of 7 (1,374 Views)
04-19-2013 12:26 PM in reply to: RayFeiler
Ray,
Best Regards,
Scott McFadden
Panygeric
Message 5 of 7 (1,301 Views)
04-30-2013 04:56 AM in reply to: Cadmanto
OK - Thanks! Hopefully this is something that will be in the future or just got overlooked?? :manembarrassed: It's a fairly common  usage thread type - think of  those feed screws w/ the round spinning turnhandles you find on A LOT of larger shop equipment....
*Expert Elite*
mrattray
Message 6 of 7 (1,292 Views)
04-30-2013 06:24 AM in reply to: Cadmanto
That's surprising. I've never had cause to use ACME threads, but I would expect to use them before some of those other odd thread standards Inventor does have.
By the way, ACME threads are standard to use on any sort of jack screw, like the feed screw on an engine lathe.
Mike (not Matt) Rattray
*Expert Elite*
JDMather
Message 7 of 7 (1,292 Views)
04-30-2013 06:27 AM in reply to: Panygeric
For ACME thread type I like actual modeled threads rather than cosmetic representation.
I made an iPart with commonly used sizes.
We were just using this this morning in Dynamic Simulation to demonstrate use of the Screw Joint type.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Announcements
Need installation help?
