Inventor Forum
Inventor 2011 - thread creator oesn't work
19 REPLIES 19
Message 1 of 20
1232 Views, 19 Replies
I've a problem with using the thread creator. It doesn't work, I can't even trun it on. On the first photo You can see that chamfering is working, but on 2nd and third a thread creator no.
Best regards
19 REPLIES 19
Message 2 of 20
hermitch
Most likely the dialog is "Out of Range" of your current display setup.
Did you recently work with more than the current monitor(s).
If so try the following:
-Click the Thread Toolbutton
-Press ALT+SPACE
-Press ENTER
-Use the ARROW -KEYS to move the dialog-box until it appears on screen.
[EDIT]Typo[/EDIT]
Message 3 of 20
salariua
I don't think this is the issue but nonetheless please check if you have the thread.xls in design data folder.
Go into Inventor / Mange / Projects and check what is the path to Design Data under Folder Options. If it says default then go to Tools / Application Options / File / Design Data.
Browse to that folder and check if you have a file called thread.xls in "Design Data/XLS/en-US"
default folder for Win7 Inventor 2015 is C:\Users\Public\Documents\Autodesk\Inventor 2015\Design Data\XLS\en-US
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 4 of 20
in reply to: hermitch
I do not work on more than one monitor, just sometimes I'm conecting to the TV, but not as a two working together monitors. Base problem is if I will click toolbutton he is not selected like others, it looks like this toolbutton is not turned on. I'll try this solution with moving the dialog-box and give reply.
Message 5 of 20
in reply to: salariua
I'll check this today in the evening and let you know.
Message 6 of 20
hermitch
If the Thread.xls would be missing or the path-definition to Design-Data folder in Options/File would be wrong, an Error Message would appear onscreen.
Certainly this one could be out of range also...
Furthermore if you add a threaded hole by using the hole command; does this work?
Would be an indicator for the thread.xls issue.
Message 7 of 20
salariua
Yes, hweier is correct, if the xls is misisng an error apears, I have rename my thread.xls file and got the error.
When you start the thread command, and you move your mose over a face, do you see a thread showing up like in my image bellow?
This will tell you if the command is working but the window is out of screen (or behind main Inventor window).
Adrian S.
blog.ads-sol.com
Message 8 of 20
JDMather
It appears that your intent is to thread extruded circles.
What happens if instead of extruded circles you use the Hole features with Threaded option?
Message 9 of 20
hermitch
Nice solution to get deeper into the issue!
Message 10 of 20
This is not working like on your gif.
Message 11 of 20
salariua
Are you selecting a cylindrical face?
Have you tryied JD's question? Hole feature with thread is working?
Adrian S.
blog.ads-sol.com
Message 12 of 20
JDMather
Does Tapped Hole work?
Have you installed all Service Packs and Updates?
Do you have MS Excel on this machine?
Message 13 of 20
in reply to: JDMather
I'll check this at he evening, now I dont' have acess. Everything instaled without any errors, I'll check this hole thread today evening
Message 14 of 20
Also thread.xls file exist, but this file only have ISO library
Message 15 of 20
Tapped Hole doesn't work
Service Packs and Updates for Inventor? for XP I have SP2
MS office installed
Message 16 of 20
hermitch
Looks like your thread.xls been modified ending up corrupted.
You could either run a repair installation (recommended) or locate the original thread.xls file on the installation package and copy into the active Design Data folder of your installation.
Message 17 of 20
My friend have the same version of this Inventor and at the begining this toolbutton was working, but now also no. I'll try to install Sp2 for Inventor, maybe this will help.
Message 18 of 20
I've checked now and this is working. Generaly I'm happy, but I don't know why it stared to working, maybe some update?
Message 19 of 20
JDMather
Create a Windows Restore Point in case it stops working in the future.
Message 20 of 20
Good idea, I'll do like that, right now I'm closing subject.
Best regards
