Inventor General Discussion
Member
tzong
Message 1 of 8 (1,592 Views)
Accepted Solution
Inventor 2011: Does threads show in section view
1592 Views, 7 Replies
07-06-2010 08:36 AM
English is not my first language, so I have problem to discribe my question.
Question:
Does threads show in section view?
I found the inventor 2011 represent the threads with dash line.
Can it be present by teeth?
|_|  |_|  |_|  |_|  |_|  |_|  teeth   instead of    - - - - - - - - - - - - -  dash line
Please see my attached bmp file to understand my question.
Thank you so much.
Tzong
The "Threads" in Inventor are a BMP image applied to the surface, for real threads you would need to use the "Coil" feature and physically produce the threads on your part.
*Expert Elite*
blair
Message 2 of 8 (1,579 Views)
Re: Inventor 2011: Does threads show in section view
07-06-2010 08:55 AM in reply to: tzong
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 340.52
SpacePilot Pro 3.17.7, 6.17., 4.11
Distinguished Contributor
kstate92
Message 3 of 8 (1,552 Views)
07-06-2010 10:59 AM in reply to: blair
I still would love to see an option when creating a detail view that, when a threaded area is selected, would show the actual thread profile based on the thread information from the model (acme, buttress, etc.).
KState92
Inventor Professional 2014 64 SP2
Windows 7 Pro 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
Member
tzong
Message 4 of 8 (1,527 Views)
07-06-2010 01:35 PM in reply to: blair
thank you, blair.
To create real threads with Coil feature, what are the threads informations required?
any suggestion of good website or book?
*Expert Elite*
blair
Message 5 of 8 (1,522 Views)
07-06-2010 01:56 PM in reply to: tzong
The "Machinist Handbook" from Industrial Press is probably one of the better books out there. I believe the 27tth edition is the current version.
You should be able to Google "Industrial Press". You might also find it available on Amazon, both new and used copies.
Win7-64
jason.stephens
Message 6 of 8 (1,520 Views)
07-06-2010 01:59 PM in reply to: tzong
You could use Machinery's Handbook or the thread.xls file located in the Design Data folder.
HP Z800 8 Cores, XP64, 32GB Ram, Quadro FX4800
*Expert Elite*
JDMather
Message 7 of 8 (1,512 Views)
07-06-2010 02:06 PM in reply to: tzong
tzong wrote:
thank you, blair.
http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%204.pdf
Here is a tutorial (written for another CAD program - but you should be able to figure it out.
Need to know major diameter, pitch and length normally given in thread note.  Generally 60° profile with perhaps point modification as indicated in Machinerys' Handbook.  For visual purposes probably don't need to get too detailed.  For manufacturing purposed the machinist generally just wants the thread note (no modeled threads).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
blair
Message 8 of 8 (1,508 Views)
07-06-2010 02:12 PM in reply to: tzong
You know, I always forget about pulling data from the THREAD.XLS file. I always head back to the Machinist's Handbook.
Win7-64
Announcements
Need installation help?
