Inventor Forum
Inventor 2011 Crash when changing realistic appearance (64-Bit OS)
7 REPLIES 7
Message 1 of 8
1448 Views, 7 Replies
Hi everyone, did any of you got these problem? I am using Windows 7 Pro (64-Bit) with Autodesk Inv 2011 (64-Bit).
I normally use this feature: "Realistic Appearance" and changing the material. However, when I accept (Clicked OK), the application crashed on me!
Please take a look at the error and the image...
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    Inventor.exe
  Application Version:    15.1.0.28200
  Application Timestamp:    4c5b0492
  Fault Module Name:    ntdll.dll
  Fault Module Version:    6.1.7600.16559
  Fault Module Timestamp:    4ba9b802
  Exception Code:    c0000005
  Exception Offset:    0000000000033c58
  OS Version:    6.1.7600.2.0.0.256.48
  Locale ID:    2057
  Additional Information 1:    9e70
  Additional Information 2:    9e70145f4ec18f05db6f3f4987ea802a
  Additional Information 3:    3bf4
  Additional Information 4:    3bf456524582f5f6a2eeae6852562da9
7 REPLIES 7
Message 2 of 8
Uhhh... is there a fix for this issue? Anybody?
Message 3 of 8
cbenner
I doubt you will get any help without listing your Inventor and full system specs.  Did you send in the crash report when the program went to the desktop?  Any number of things can cause this to happen, no way to know without a lot more information.
Message 4 of 8
in reply to: cbenner
Here is my system spec. Please take a look at my snapshot... the application crashed on me many time and I am getting fed up! Can't even use realistic appearance! Smiley Sad
Notes: this is system 1 and the other machine is the same. There is no point posting both images.
Message 5 of 8
Here is my crash report file... I hope this helps!!
Message 6 of 8
RobJV
I get the same thing when I try to add a realistic appearance to a material.  Has there been a fix added for this?
Even if I hit cancel on the materials dialog box, I get a crash (no inventor dialog only microsoft comes up).
Same OS and Inventor version as yours
Message 7 of 8
I am afraid the developers are not going to fix this for inventor 2011 edition. They are going to ignore this bug and force everyone to update / buy a newer version. 😞
In my point of view, three of the person I knew, they also have this problem. They are engineer and they always got this hedious crash. Sadly, I've been telling autodesk to sort this issue. However, I think they refuse to fix this bug.
Message 8 of 8
LimaLina
Hi: I use Autodesk Inventor 2012 (Evaluation version).
Problems localisation:
-          In "Drawing" application for "Inventor".
-          Inventor and all operating system (Os) are crashing roughly and the system restart.
Problems results:
-          The whole operating system crash;
-          All my data are lost (drawings, documents, etc.);
-          Any message are displayed for more information problem crashed;
Problems onset:
All this when I try only to use the function "Break" on my form (basic form).
Problems picture:
look at this image
