I have a user that has an issue when checking in Inventor drawings with a viewable.
When he check in without creating a dwf viewable the checkin time is normal.
When he creates a viewable at check-in, the time to complete can be very long. (1+ hour)
The files he checks in are small (3 part) assemblies.
It appears to be some type of setting (software or pc) but I am not sure what that might be.
Any ideas?
FYI, this sounds like more of a Vault question that should be posted on the Vault forum.
What version of Vault are you using?
I found this link on line. I know it is for an older version (2008), but take a look through it and see if there is anything you can see that applies to your situation. I know I read something in one of the first few paragraphs that seem to speak to what you said.
http://images.autodesk.com/adsk/files/dwf_settings_in_vault.pdf
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Have a different user log in to the machine in question and try checking the same file into Vault with dwf.
This will tell you whether its a software issue or a Windows User Profile issue.
If all is ok with the other user on the same machine it would be a Windows User Profile issue and it will need to be deleted and recreated.
