Inventor Forum
Inventor 2010 content center not opening
9 REPLIES 9
Message 1 of 10
588 Views, 9 Replies
HI
I'm not able to open to inventor 2010 content center in user login but where as in i'm able to open inventor 2010 content center in administrator account.Please do reply me with solution...
9 REPLIES 9
Message 2 of 10
So what happens when you try to open content center with your user account?
Can you post a screen shot of the error?
Message 3 of 10
blair
Minimum account requirements are "Power User".
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 10
Sure attach the file n get back to you.
Message 5 of 10
hi, John,
points to be noted.
1. I have installed two version of Auotdesk Inventor 2010 & 2012.
2. I can do anything in Administrator Account of the Local Machine.
3.When i log in as a one of the user Account i am not able to See, Content Center option in the inventor 2010.
4Some times if i restart the machine i am able to see the option But when i open the Inventor 2012 in the User Account to work on some project, and come back again in Inventor 2010 Content center option is vanished.
5. But this thing never happens in Administrator account.
6. Operating System we are Using is Win7 64 BIT.
7. i have few Winxp 32 bit Machine. Where everything works fine.
8. we are Running Network License.
9. I have tried Reinstalling Both the Autodesk Products. not Worked.
10. Formatted the System Re did Everything.. But Still Didnt Worked. Any Help on this problem will be Apreciated.
Message 6 of 10
blair
Please check in the Autodesk Requirements for Inventor, it stipulates a minimum level of "Power User" is required and "Administrative" level is preferred.
You can always set up your network users of have local Administrative privileges.
Delta Tau Chi ΔΤΧ
Message 7 of 10
in reply to: blair
Hi
    I hope you are doing well.I'm here with some updates deatiled below.
                                      The Hardware requirement for Autocad 2010 and 2012 is outstanding one, and the network user are set up with Administrative privileges.Do i need to provide a power user privilege.
                                       When i use autocad inventor 2012 after working with auotcad inventor 2010.It prompts me with a message would you like to re-register as we are using  common network license for both.
Message 8 of 10
blair
Please just humor us and try a minimum of "Power User" settings. Somewhere in the Autodesk paperwork is a minimum requirement of "Power User"
Delta Tau Chi ΔΤΧ
Message 9 of 10
After running 2012, try right-clicking the Inventor 2010 shortcut and Run as administrator.
Message 10 of 10
 Hi
I used that option too still the problem exists.
