Inventor Forum
Inventor 2010 Bill of Materials Error
10 REPLIES 10
Message 1 of 11
1281 Views, 10 Replies
I tried to export the Bill of Materials to an Excel file and was met with: "Couldn't open database--Exception: Unable to create file."
Why did I get this error? My IT manager has stripped everyone of their "administrators" rights. could this be the problem? Or could it be that he messed up the re-install last week?
10 REPLIES 10
Message 2 of 11
jdits7
What OS are you running, and what version ie... 32 or 64 bit.
jdits7
http://inventortopix.blogspot.com
jdits7
Autodesk Inventor Certified Professional
Blog - http://www.inventortopix.com
Twitter - @InventorTopixJD
Message 3 of 11
Windows XP Pro w/SP2
32bit
Message 4 of 11
Forgot to mention... I did not have this problem until today. Last time I needed to run a BOM I had full rights and a re-install of Inventor had NOT been done. (The reinstall was for another problem with the Network License)
Message 5 of 11
mcgyvr
Not sure if its the cause but Inventor requires users to be at least a "power user" anything less and you will have problems...
Message 6 of 11
jdits7
Just tried on one of our machines that has the same OS that doesn't have admin rights and all went well. Might need to try a uninstall and reinstall. Not sure though.
jdits7
jdits7
Message 7 of 11
Thanks for your help.
Are ready for this? I just rebuilt the assembly, testing the BOM-to-Excel. All was working well until I got to one sub-assembly. It turns out that this sub-assembly was corrupted somehow. This, I guess, was the culprit. Completed the assembly,minus the bad sub-assy, and all is well. I just tried to BOM-to-Excel this one file and no good. Guess I will have to rebuild that assembly.
thanks for the help tho. I was kinda hoping for some ammo to use to get back my "power user" rights tho! maybe I can still use this!
mike.
Just a quick question: Could having only 2 gig of memory contributed to this? (Not the bad assembly, just this in general) Edited by: lycheamdog on Jun 2, 2010 1:42 PM
Message 8 of 11
jdits7
Glad you got it figured out. One way to get your admin rights back, tell them you need to upgrade to 64 bit OS and upgrade to Win 7. I am running Vista x64 and now have full admin rights.
jdits7
jdits7
Message 9 of 11
Or both... have your IT admin set users to Power User, so that IV can
write to the registry. Also, make sure the admin used these tips for
install:
http://teknigroup.com/tutorials/InstallAdsk2009.html
Dennis Jeffrey, Autodesk Inventor Certified Expert
Subscribe to the free "The Creative Inventor Magazine now available at:
http://teknigroup.com/CI-Subscribe-Login.asp
Message 10 of 11
If only it were that easy! We have a saying around here, it goes like this:
I would rather have a root canal preformed by a monkey! Why? because it would be less painfull!!
Message 11 of 11
then what ever they are paying you to work there isn't enough to stick
around.
