Inventor Forum
Inventor 2009 Thread Display.
2 REPLIES 2
250 Views, 2 Replies
I was wondering if anyone had a soultion to the problem I have.
If I draw a cube 100 x 100 x 100, then I chamfer one of the edges, I then create a threaded hole (thru all) on the chamferd edge.
When I come to create a drawing of the above, the thread on the hole will only display on the side elevation.
When I create an end elevation I have no thread form shown.
I have attached a file to highlight what the problem is.
Hopefully someone can help
2 REPLIES 2
mcgyvr
Looks like a bug..Does it in 2010 also. (might be a drafting standard to display like that but I doubt it)
Thank you for raising this question. It is most likely a bug/limitation. The issue has been reported to the Inventor development team. I will let you know if there is some workaround.
