Inventor Forum
[Inventor 2009] How to make actual knurls
5 REPLIES 5
kylewill0725
3348 Views, 5 Replies
Pretty straight forward question. How does one make a knurl on a cylinder? I don't mean using textures but actual cut in knurls.
5 REPLIES 5
JDMather
in reply to: kylewill0725
Coil surface.
Sweep.
Pattern.
(how is that for a straight-foward answer?)
This was done using one sketch.  (for the entire part... ... and I just realized that I did too much work at that)
If I do it again, I think I wouldn't go quite so deep on the triangle and increase then pattern count to compensate.
Post for step-by-step instructions if  you can't figure it out (best to post your actual ipt file).
JDMather
in reply to: JDMather
Well,
it really bothered me that I made my one and only sketch more complicated than needed - so I did it over.
kylewill0725
Ya that's pretty good thank you 😄
JDMather
ahhhh except I just realized I didn't need to sweep unless I wanted to change the angle of the profiles perpendicular to the paths, other wise I could have just used the Coil-Cut (twice).
mpatchus
With a little thought and using tools in different ways, you can pretty much create anything in Inventor.
Here's one of checkering on a pistol grip, which is basically knurling anyway.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
