Inventor Forum
Inventor 2009 : flat pattern problem
3 REPLIES 3
380 Views, 3 Replies
Hello ,
iam facing a problem in the sheet metal flat pattern lines , when saving the flat pattern as a DXF all center lines (representing bend lines) are converted to continuous lines which cause a problem that my CNC bend machine software can not read the bend lines as a continuous line .
So is there any way to enable the saving of center lines when exporting the DXF file from the flat pattern
3 REPLIES 3
-niels-
Welcome to the Forum!
When you save your dxf, did you check the layer settings?
You can set the linetypes and visibility here before you save your dxf.
Hope this helps.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
mgeurts
in reply to: -niels-
Many Thanks really appreciate it
