O/S?
Do you mean Inventor 12 or Inventor 2012?
Are you current on all SP's and Hotfixes?
Did you follow all the pre-requisites to install Inventor
1.) Logged in with Admin Priv
2.) UAC slider set to it lowest position
3.) Depending on software, you may need to stop/disable your A/V software
Are you current with the Microsoft Certified graphics card driver for your hardware.
Is it possible to post a screen capture of what you are working on.
Have you tried changing the settings in the Applications>Hardware>Graphics (Performance, Quality, Compatibility)
Hello Roy,
Would it be possiable to create a pack and go?
How many parts on the assembly? (bottom right numbers)
Warren.
1) How many parts are we talking ?
2) Any projected edges and how many?
3) Any adaptive Parts, Sketches?
4) All sketches fully constrained?
5) Any iparts, iassemblies?
6) Are you using Content Center parts?
7) Any imported Parts, How many?
@RoyRR wrote:
Win 7 64 bit yes 2012 and yes 1-always 2-UAC disabled 3-nothing else is running MS drivers have nothing to do with nvidia card but yes drivers are up to date tried quality but i need highest quality for screen captures, still disappointed about low AA and lack of rendering for sectioned view
What do you mean by "tried quality but".. quality will give you the best display with the highest AA..
What is it set to now?
And post your exact driver version. (like 307.83)
I had NO problems with antialiasing on 2012.. It was better than any other version
What do you have for tools..application options..display tab (display quality).. should be "smoother" or something like that..
Also what do you have for minimum frame rate..
2012 was a very stable release IMO with great graphics.
Your issues scream graphics driver problems.. You can try rolling back to an older version too but anything from 2013 "should" work just fine.
Microsoft certifies drivers (WHQL?) for running Driect X, which is what Inventor uses. Is your graphics driver cetified by Microsoft?
By the way, your problems with the forum are likely due to addthis.com being blocked either by your browser or your IT department.
@Blair wrote:
The most current Nvidia driver is 33.23, it was released March 10th. There have been a couple of post the this driver has solved some AA problems.
Driver is 335.23 Mar 10 2014..
@Blair wrote:
Thanks, early in the morning here, fingers still not up to speed. 🙂
I've got your back man
Are you sure it's not being blocked upstream (by a corporate firewall, for example)? If I set AdBlock to block AddThis.com I get the symptoms you're reporting, if I turn that filter back off it suddenly works again. So, this is logicaly the most likley cause.
Something with the new format web-site, I can't add files, insert graphics or edit my posts from work either. Same thing happens with IE10, IE11, Safari and Mozilla FireFox, all from my work machine. It was fine till the forum changed last November.
