Anyone know how to replace a model reference in and Inventor 11 .idw file. - It seems this is something easy to do in Inventor 12 but I don't see how to do it in 11..
Solved by SBix26. Go to Solution.
Solved by mcgyvr. Go to Solution.
I think you mean Inventor 2011 and Inventor 2012.. If so the "replace model reference" command was included in both versions and functions the same. In 2010 it was only included as part of the subscription advantage pack available to subscription customers only.
I have Inventor 11 and do not see where to access this command. I can't find any reference to it in help either.
In Version 12 it is in Manage Tab > Modify Panel > Replace Model Reference
I still think you have 2011 and 2012... NOT 11 and 12
Inventor 11 was released in 2006 then next year they went to versions matching the coming year so Inventor 12 was actually INV 2008. Neither 11 nor 12 had the replace model reference button as it wasn't released till what I said above.
"maybe" it wasn't added till a service pack in 2011.
Inventor versions/release dates
Inventor 1 "Mustang" 9/20/99
Inventor 2 "Thunderbird" 3/1/00
Inventor 3 "Camaro" 8/1/00
Inventor 4 "Corvette" 12/1/00
Inventor 5 "Durango" 9/17/01
Inventor 5.3 "Prowler" 1/30/02
Inventor 6 "Viper" 10/15/02
Inventor 7 "Wrangler" 4/18/03
Inventor 8 "Cherokee" 10/15/03
Inventor 9 "Crossfire" 7/15/04
Inventor 10 "Freestyle" 4/6/05
Inventor 11 "Faraday" 4/6/06
Inventor 2008, "Goddard", 3/26/07
Inventor 2009, "Tesla", 3/24/08
Inventor 2010, "Hopper", 3/24/2009
Inventor 2011 "Sikorsky", 3/25/2010
Inventor 2012 "Brunel" 3/21/2011
We are worse off than I thought.. and time sure flies.. We have many copies of Inventor 11 and one of Inventor 2012 - that is why I cannot find the feature.
Thanks for the wake up call !
OK, in Inventor 11, the simplest way to change the model reference for one or two drawings is this:
- Rename (temporarily) A.ipt.
- Open A.idw, which now cannot locate A.ipt, and asks you where it is.
- Navigate to B.ipt, which, if it is a copy of A.ipt, will satisfy A.idw; save A.idw
- Rename A.ipt back to its original name.
This sounds rather complicated, but it is very quick for one or two files. Basically, you're hiding the original reference so that Inventor has to ask, then showing it the new reference.
If you have a bunch to do, then Design Assistant will save you some mouse clicks, I think.
Tried the following:
What if doing this causes IV to give the following message, "Selecting the file C:\...\A.ipt creates a cycle. Please Choose a different file."? (I am trying to make 'a family of prints' for a family of parts. They generated be the same parent iPart and I think that the idw was created with the iPart itself.
I tried to do this in DA and when I save the changes, the NAME field reverts back to the originally loaded file.
Any help would be greatly appreciated.
MZimmerle
2009 Inventor Suite
Windows Vista Business 32 bit (x86)
Intell Core2 Quad Q6600 @ 2.40GHz / nVidia FX1700 (512MB) / 4BG RAM
