Inventor Forum
Inventor 11 and Windows 8.1
8 REPLIES 8
Message 1 of 9
dannyc2
534 Views, 8 Replies
I loaded inventor 11 on my Windows 8.1 machine.
It started and contacted mama (registered itself with AutoDESK).  It then ran twice more but I could not open any files (SCHEMA Failure).
Now it doesn't open at all.
Any Suggestions?
8 REPLIES 8
Message 2 of 9
Martin_Goodland
in reply to: dannyc2
You will need to go back to using a WinXP machine or upgrade to a newer version of Inventor (I believe 2014 & 2015 are supported on Win 8.1).
Regards
Martin
Inventor 2023
Message 3 of 9
dannyc2
in reply to: Martin_Goodland
Yea, like that is going to happen. That's how many thousands of dollars??
Even though I agree with you - just too much money for me.
Still - it DID run and talk to mama - then it stopped running.
Think Autodesk had a hand in that?
Message 4 of 9
DarrenP
no windows 8.1 came years after inventor 11 did
even 2014 has problems with windows 8.1
DarrenP
Message 5 of 9
Martin_Goodland
If you have to use Inventor 11 then you will need to get hold of a computer that runs XP (there seem to be lots on e-bay). You could always just use it for Inventor and use the newer machine for everything else.
As DarrenP said even Inventor 2014 which is 7 years newer than Inventor 11 does not work properly on Win8.1
Regards
Martin
Inventor 2023
Message 6 of 9
mrattray
Versus how much money you have already spent (time+hardware) plus how much you will spend (time) trying to force Inventor "11" (I assume you mean 2011) to run on Windows 8.1?
Mike (not Matt) Rattray
Message 7 of 9
Martin_Goodland
in reply to: mrattray
No he really does mean Inventor 11. There are some files posted in a different thread and they are Inventor 11 files not 2011.
Regards
Martin
Inventor 2023
Message 8 of 9
mrattray
@Martin_Goodland Wow.
@dannyc2 You should be aware that you are actually in violation of your EULA. You're only allowed to be behind a few releases. There's a few threads discussing this here.
Message 9 of 9
dannyc2
Thank you all for the replies - yes it is a problem, was hoping someone found a fix. Apparently it is Windows 8 that's the problem - and not just for Autodesk. But that is life, I guess.
Have considered getting an XP machine to just run it.
Was hoping that running in XP emulation mode would work.
