Inventor Forum
Inventor 10 Series - service packs?
22 REPLIES 22
Message 1 of 23
GarretV
2352 Views, 22 Replies
I had to re-install Inventor 10/MDT 2006 the other day. I came to the support site to retrieve all the service packs, and I see Autodesk has discontinued anything previous to 2008. Is there somewhere else I can get these? Is there a mirror site?
Thanks.
22 REPLIES 22
Message 2 of 23
in reply to: GarretV
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019
I don't know what happen to 2006/10 but I do see a listing for Inventor
9 series at that link.
Message 3 of 23
I'm looking for Inventor Series 8 service packs but don't see any on this list. Where can I find those?
Message 4 of 23
RobSinglehurst
Do you mean Inventor 8 or Inventor 2008? I've got the service packs for everything since Inventor 6 circa 2002, 2003.
If you send me your email address I can "mailbigfile.com" them to you.
Cheers,
--Rob Singlehurst
IV2010 SP2
Dell Precision PWS690
Quadro FX3500
DirectX 191.87
SpaceExplorer 4.04
3DxWare 3.9.0
Intel Xeon 3GHz
4GB RAM
WinXP Pro SP3
Cheers,
--Rob
Inventor 2024.2
Message 5 of 23
Terrific! I'm looking for Series 8, not 2008.
Where can I find your email address?
Message 6 of 23
I know that Dennis Jeffery's has them on his web site. For Inventor Ver 10
http://teknigroup.com/ Edited by: Doug_DuPont on Apr 9, 2010 1:23 PM
Message 7 of 23
RobSinglehurst
If you can post your email address I can then use mailbigfile.com which will email you a link to then download the file. There was just one service pack for IV8, it's about 15Meg.
I've attached the txt file to this post.
Cheers,
--Rob Singlehurst
IV2010 SP2
Quadro FX3500
DirectX 191.87
SpaceExplorer 4.04
3DxWare 3.9.0
Intel Xeon 3GHz
4GB RAM
WinXP Pro SP3
Cheers,
--Rob
Inventor 2024.2
Message 8 of 23
Thanks for the help. I've got Autodesk Inventor Series 8 (not 2008).
My email is: cadnov8@northnet.net
Message 9 of 23
RobSinglehurst
You should be getting an email from mailbigfile.com with a link to download the file soon.
I've tried the link and it works fine.
Hope that helps,
Cheers,
--Rob Singlehurst
Cheers,
--Rob
Inventor 2024.2
Message 10 of 23
RobSinglehurst
Did you get the email and manage to download the SP?
Cheers,
--Rob
Inventor 2024.2
Message 11 of 23
Yes, I got the email and downloaded the SP (verified in "About Autodesk Inventor") - I was away for a few days. But I'm still having the same problems. When I launch Inventor, the Open dialog box appears. I've done several different things:
* opened a new Standard.ipt file
* opened a previously created part (when I had this loaded on my computer years ago)
* changed to a different project
I've also closed the Open dialog box and selected a new part and a new assembly to begin from. But Inventor still crashes.
Inventor still crashes. I've tried various combinations of the above as well.
Are there any other fixes available for this problem?
Is there possibly something wrong in my Windows registry?
Message 12 of 23
RobSinglehurst
Are you using a supported graphics card / driver combination? Did you install with Anti-Virus disabled?
Cheers,
--Rob Singlehurst
Cheers,
--Rob
Inventor 2024.2
Message 13 of 23
Yes, I installed with the AV disabled, but no, the graphics card is not supported. However, when I first bought Inventor and installed it - back in 2004 - everything worked fine.
Message 14 of 23
RobSinglehurst
Try using "Software Graphics" in Tools > Application Options > Hardware. If this works then it is almsot certainly down to your graphics card / driver.
Cheers,
--Rob
Inventor 2024.2
Message 15 of 23
It looks like it worked! Thanks!
I went to Tools > Application Options and selected "Override recommended settings - use Microsoft GDI Generic OpenGL driver."
Now I remember that when I bought this laptop the graphics card was not an Autodesk certified card, but this work-around works. Thanks again.
Steve
Message 16 of 23
RobSinglehurst
Good, I'm glad you've got it working!
Cheers,
--Rob Singlehurst
Cheers,
--Rob
Inventor 2024.2
Message 17 of 23
Thanks! You helped me alot!
Message 18 of 23
in reply to: RobSinglehurst
I see you helped someone out with getting service packs for inventor 10. I am in need of the service packs for reinstallation. If you can help I would be greatful my email is p_psinc@bellsouth.net
Message 19 of 23
http://teknigroup.com >> Downloads link.
Message 20 of 23
Hi was wondering if you have Autodesk inventor 10 service pack, and if you can send it to me
If so my email is daniel@ad-distributors.com
thanks alot
