Inventor General Discussion
New Member
zachdixon0118
Message 1 of 8 (706 Views)
Invalid serial number
706 Views, 7 Replies
01-19-2013 12:48 PM
I am getting the message of invalid serial number. I would like to speak to someone directly to help me solve this problem instead of flipping through self help information. Thanks
Curtis_Waguespack
Message 2 of 8 (697 Views)
Re: Invalid serial number
01-19-2013 01:47 PM in reply to: zachdixon0118
Hi zachdixon0118,
Visit the Installation & Licensing forum. Autodesk staff actively monitor that forum working to answer your installation and licensing questions.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Distinguished Contributor
donovan.cox
Message 3 of 8 (687 Views)
01-19-2013 02:42 PM in reply to: zachdixon0118
Things to watch out for are, entering a network serial number into a standalone install. There's also accidentally using the wrong year version or wrong product version, like using an ultimate serial number for a premium install.
New Member
zachdixon0118
Message 4 of 8 (670 Views)
01-19-2013 07:20 PM in reply to: donovan.cox
The network/standalone problem might be it. My thing is that the company I work for has Inventor on all of its computers and they had it installed before I started employment. They know less about the installation process than I do but I would assume that they ran it as a network. For some reason I probably installed it as a standalone instead. Is their any way to change this without reinstalling?
Distinguished Mentor
john.retzlaff
Message 5 of 8 (653 Views)
01-20-2013 05:56 AM in reply to: zachdixon0118
Only way to fix is to reinstall.
John Retzlaff
*Pro
ampster
Message 6 of 8 (586 Views)
01-21-2013 05:57 AM in reply to: zachdixon0118
good answers so far to your question but just in case you're not aware, this isn't the place to expect to communicate directly with Autodesk.  You're question seems to indicate that was what you were hoping for.
Valued Mentor
Mason-Paul
Message 7 of 8 (578 Views)
01-21-2013 06:28 AM in reply to: ampster
There is a separate board for installation problems here
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
I believe that this board IS MONITORED by Autodesk.
Maybe the this board's moderator can move/copy this question over
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
philip.s
Message 8 of 8 (530 Views)
01-21-2013 01:53 PM in reply to: Mason-Paul
Typically your best bet in this situation, outside of checking to make sure you're using the appropriate serial number and product key (not previous versions) and installing as the right deployment (standalone vs.network), would be to contact our License Assitance team for direct support.
Philip Schmelzer
