yeah Ive got a good reason,
I have multiple assemblies that use the same harness.
So I create the harness in the first top level assembly and then turn its adaptivity off in all the other top level assemblies that use that harness. the top level assemblies all use the same harness but other components of that top level assembly change.
This is why I wish harnesses could be created in their own assembly file and simply inserted and then constrain the connectors to their correct spots and routed as necessary Constraint information,routing information, etc..would be stored in the top level assembly and in the harness file you could specify a maximum wire length so that you insert the harness and if you constrain the connectors to locations that would exceed the specified max wire length this would generate an error similar to "You have exceeded the max wire length for this assembly, please create a new harness for this project" or something like that.
This would be huge for me seeing as how I have TONS of products that use simple wire assemblies like 1 wire with a ring terminal on each end. and having to recreate even the simplest wire assembly has become time consuming. When just dropping that harness component into an assembly and constraining the end connectors would be great.
As for the drawing of the harness I wish there was a straighten wire command to allow me to show just the straight wire with the connectors at the end, not using the nailboard is a pain even for simple wires
Having to recreate the same harness that might be used in 50 top level assemblies is a total pain in the ass with the harness module the way it is now. I would hate to be a computer manufacturer or someone who uses the same ribbon cable assembly for tons of different top level assemblies.
But thanks WEI I found it where you have hidden it.
