Inventor Forum
INV 6 Offset Workplane question
6 REPLIES 6
Mikerknoxer
158 Views, 6 Replies
In Inventor 5.3 I could start the Workplane command, click on an existing workplane and then click on a face parallel to that workplane to set the offset distance for my new workplane. Now when I do that in INV 6 it doesn't place the new workplane at the face, but half way in between the previous workplane and the face. Is there any way I can still do this? This feature is crucial to some of the tubular parts I design. Thanks in advance. Mike
6 REPLIES 6
in reply to: Mikerknoxer
Start workplane command, click and drag the existing workplane or surface,
release mouse button and enter the offset you want.
ncabilan
"Mikerknoxer" wrote in message
news:f13c2d1.-1@WebX.maYIadrTaRb...
To get an offset workplane, just click and drag
(hold down the left mouse button) from the first face (or plane)
HTH
Rory
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
In
Mike
If you want to offset to a parallel face begin the
workplane command, click on the 1st surface, RMB then select create point and
select a corner on the face you want to offset to and the plane will be created
on that parallel face.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
Tampa
Bay...Superbowl bound!!!
In
Mike
May be that you have to drag it off further than
you might expect for the offset dialog to pop out.
~Larry
In
Mike
I just fired up 5.3, and you had to select a point to create a parallel
workplane. If your first selection was a face or a workplane, it wouldn't
allow you to select a second face for the offset.
Loren Jahraus
Autodesk Inventor Workflow Team
Mikerknoxer
Thank Loren and Sean. I had forgotten that you did indeed have to pick a point on the face in 5.3. I tried the RMB Sean and it worked great. Thanks a lot, Mike
