Inventor Forum
Inv 5 crashes when opening an idw file
6 REPLIES 6
283 Views, 6 Replies
Greetings,
Several of our idw files cause Inv 5 (not 5.3, just not much action on the
"Legacy" board) to crash when we try to open them. Some machines are more
problematic than others. The one that is most problematic is a brand new
Dell.
Crash log pretty consistent with the following message:
' Crash Information
' ACCESS_VIOLATION
' Build: M.5.5000.5064bSP2 - Date: Sun 10/21/2001
' Last command started class DLxSelectCmd
' Last request completed
' Call Stack: Address = 20 Gr.dll 0x0000A0C3 SMData.dll 0x0000F777
SMData.dll 0x0000F542 SMData.dll 0x0000E323 SMData.dll 0x00010C0D SMData.dll
0x0001100F SMData.dll 0x000111F3 SMData.dll 0x00013F11 SMData.dll 0x000153D4
DL.dll 0x001CFA05 DL.dll 0x001CE8D6 DL.dll 0x00067A16 DL.dll 0x00111857
DcKernel.dll 0x0001FBC3 Du.dll 0x000A0DD9 DL.dll 0x0006D958 DL.dll
0x001178FE DcKernel.dll 0x0000F12E DcKernel.dll 0x0001E19D DL.dll 0x000F0464
Any insite?
Howard Delano
Design Engineer
Stainless Design Concepts
A Division of CVD Equipment Corporation
1117 Kings Highway
Saugerties, NY 12477
Phone: (845) 246-3631 (ext. 38)
Fax: (845) 246-1595
E-mail: hdelano@stainlessdesign.com
6 REPLIES 6
jiml
we need the computer spec and do you have sp2 installed for Inventor what os and sp you have on the os
flash
Jim,
According to the info he posted he is using R5 sp2. It looks like the crash happened during a selection process in the idw. Is the date correct Howard in the crash log? 10/21/01 last year? If so, you may have to recreate the idw from scratch. I'll look in my archive tools for R5, there may have been a dll that you can replace on your R5 install that would let you open some crashed idws. I'll email it to you on Monday, if I still have it with instructions. Flash
Flash,
I assume that is the correct date. We got the
software Jan/Feb of this year. Have installed SP 1 & 2.
It happens on a couple of machines.
First discovered on our new Dell Dimension
8200
NVIDIA GeForce4 MX 420
Driver 7/16/2002 Ver: 3.0.8.2
Swap File: 1536 MB
RAM: 512 Mb
P4 2.4 Ghz
I was able to open one of the 2 files that crashed the new
Dell on an older machine (which has 768 Mb of ram), so I played around with swap
size, undo file size, etc. At one point neither file would open on the "old"
machine either after i had checked the Precise View Generation box.
Look forward to any help you can offer.
Howard
Jim,
Flash
jiml
what os
flash
Howard,
Can you post some of the idw's with the models to customer files so I can take a look at it? Still looking for the dll information. Flash
Older machines are NT 4.0 sp6, other is
XP Professional, sp1
what
os
