Was working fine yesturday, I place about 100 components, no problem.
Then suddenly I crash to desktop at least 90 percent of the time when I select
"place from content center" it starts to load then, desktop.
Windows 7 Pro.
Does anyone have any ideas?
Happens in all my projects, including Default.
Single user, no vault.
Solved by ferriscad. Go to Solution.
Windows 7 Pro.
When did you load SP1? Did this start to happen right after? Anything else in your environment change?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Beta SP1 worked fine, SP1 installed for a week, worked fine.
Frame generator also stopped working.
Reinstall fixed the problem.
