Inventor Forum
inv 2011 move little input window
4 REPLIES 4
ferrisb
295 Views, 4 Replies
Anyone remember how to remove, or hide this little guy?
Inv2011.
4 REPLIES 4
blair
in reply to: ferrisb
You should be able to "grab" the icon portion that has the dots on it. Not sure why yours looks like it's under the input window portion. It should be a small vertical icon to the LH of the input window.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
ferrisb
in reply to: blair
I am able to move it by selecting one of these (3) points, holding leftclick and dragging it.
But, it does not stay where I moved it, can I lock it somehow?
blair
Good question, check that you have all SP's and Hot-Fixes installed for your version of Inventor. Possibly try logging in as a different user and see if the problem persists. Preferable one with Admin Priv.
Delta Tau Chi ΔΤΧ
LT.Rusty
I don't think you can do anything about it in 2011, unfortunately.  In 2013 there's a little pulldown that has an option to pin it in place.  I drag it to an out-of-the-way position and pin it, then just use the normal window instead.  I really like the full-size menu window.
Rusty
