Inventor Forum
Intersection Dimensions in Broken Views
13 REPLIES 13
Message 1 of 14
brimal
984 Views, 13 Replies
Running Inventor 2013, when dimensioning a broken view, if an intersection is use to define the location of the leader, the dimension is created correctly but the crossing lines defining the intersection are mislocated in the view (see attached pic).
13 REPLIES 13
Message 2 of 14
Cadmanto
in reply to: brimal
You are talking about the virtual sharp intersections?
Interesting???  How did you reate the sharps?  The dimensions are accurate in location.
Or are you talking about something different.  Can you post your files?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 14
brimal
in reply to: Cadmanto
Yes, I'm talking about the virtual sharps.  I created them using the dim intersection option as I was creating the dimension.
Please see the attachments.
Brian
Message 4 of 14
mdavis22569
in reply to: brimal
were the intersections done prior or after the broken view
Mike Davis
Message 5 of 14
brimal
in reply to: mdavis22569
They were done after the broken view was created.
Message 6 of 14
mercerc
in reply to: brimal
You got me a little confused here. You mentioned you added the dimension after the broken view was created. Is that true?
The reason I ask is I can repeat what you have shown only if I create the dimension first then use the broken view command.  If I use the broken view command then dimension the part I get what is expected.
Did you do anything else to edit that view after using the broken view and before or after adding the dimension?
Charlie M
Inventor Product Support Specialist
Message 7 of 14
brimal
in reply to: mercerc
I have now tried it both ways and get the same result.  However, why should it matter?
And, no, I didn't do anything else to edit the view.
Message 8 of 14
mercerc
in reply to: brimal
As I looked at the case as my results differ from yours I seen I was using Inventor 2014 which had the results I explained earlier.
I then recreated a sample file in Inventor 2013 SP2 Update 5 and I couldn’t repeat the issue at all. I created a view in two different sheets. One I created the break view first. In the second sheet I created the break after adding dimensions. In both cases I was able to use the break command and the intersections annotation stayed in place in each.
Please check to see that your Inventor 2013 has SP 2 with Update 5 applied. Then try repeating the issue.
Charlie M
Message 9 of 14
brimal
I'm on Inventor 2013, Service Pack 2, Build 200.
Message 10 of 14
brimal
I'm on Inventor 2013, Service Pack 2, Build 200 but I didn't have any updates applied.  I just installed Update 5 but ended up with the same results as before.
Brian
Message 11 of 14
mercerc
in reply to: brimal
Would it be possible to get the file in question?
If you can’t post it to the discussion group I can arrange another method.
Also have you tried creating this as a test in another file? Creating a sample test file would eliminate the file itself if you can repeat it. As not be able to repeat it, it leaves only two avenues. One is the file itself the other being a possible issue with your user account or OS.
Charlie M
Message 12 of 14
brimal
The files are attached to an earlier post.
Message 13 of 14
mercerc
in reply to: brimal
It seems the issue is using the Include Route Center Lines. This has been reported to QA.
For a work around use the Center Line Bisector command in place of the Include Route Center lines. This will not do the radius but it will follow the view and allow you to dimension the views.
Charlie M
Message 14 of 14
brimal
Has QA reported anything back on this issue?
