Solved by Curtis_Waguespack. Go to Solution.
No file attached?
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Try IE or Chrome if one or the other doesn't work.
no file attached again..
Seems some users are having problems attaching files on this forum.. So right after you post..please check your post to see if the file has actually been attached before you go and do something else..
Hi gblmcm,
Does your file have multiple solid bodies? Are either the panels or the wing a surface instead of a solid? You can expand the Solid Bodies and/or Surface Bodies nodes in the browser to determine what you have.
I hope this helps.
Curtis
