Inventor General Discussion
Active Member
imbik
Message 1 of 7 (782 Views)
Internal cylindrical cam slot
782 Views, 6 Replies
09-23-2012 06:01 AM
I created a cylindrical cam using the feature in inventor 2013 pro. What I want to do is to create an internal grooved cam slot on it with exactly the same shape (please see attached picture). It will start from 17 mm lower the upper cam surface,  moreover will be14 mm deep and 22.5 mm thick in the slot.
I hope I could explain properly. Any help is much appreciated.
Hi! I try my best understanding the request. Attached is one of several possible solutions. Let me know if it works for you.
Thanks!
JDMather
Message 2 of 7 (775 Views)
Re: Internal cylindrical cam slot
09-23-2012 06:37 AM in reply to: imbik
Attach the ipt file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
imbik
Message 3 of 7 (765 Views)
09-23-2012 07:42 AM in reply to: imbik
Here it is, and thanks for any help in advance.
JDMather
Message 4 of 7 (728 Views)
09-23-2012 01:08 PM in reply to: imbik
Is there any reason you can't use the Cylindrical Cam Generator within Inventor?
Also,
I noticed that your first sketch and several others were not constrained.
It is pretty automatic to constrain a circle to the origin and I would pattern the slot feature rather than the slot sketch.
This might be if interest,  I (or someone) will demonstrate the Cam Generator if you can't figure it out.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Employee
johnsonshiue
Message 5 of 7 (679 Views)
09-24-2012 10:51 AM in reply to: imbik
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Active Member
imbik
Message 6 of 7 (640 Views)
09-25-2012 10:24 AM in reply to: imbik
Dear JD Mather,  thanks a lot sparing your time for me, I am always taking advantages of your comments on any issue that shared in this message board.
johnsonshiue; you probably have no idea what you have done or solved. It might seem just a cylindrical cam problem but in fact it is a part of very controversial project that may change the balance of world's renewable energy insight. After ruling the world and earning million dolars, I promise that I will remember you :smileyhappy: Cordially
JDMather
Message 7 of 7 (624 Views)
09-25-2012 11:14 AM in reply to: imbik
imbik wrote:
 After ruling the world and earning million dolars, I promise that I will remember you.
Hey - you didn't say financial security was at risk here.  I would have posted the solution if I knew it would pay off.
JD
