Hello.
We are having an issue with Inventor Pro 2013 whereby Inventor will crash when a user attempts to place the base view into in .idw (also fails when trying .dwg). This problem is extremely intermittent as the same user can get the error one time and NOT get the error the next time. The crash immediately shuts down Inventor (no error box displayed) and the "Send/Report Issue to Autodesk" window pops up.
We've applied all Inventor updates (and even removed them too) and all video card driver updates (Nvidia Quatro K2000M), but the issue persists.
I remember there was an issue with a Windows update a few versions back that forced Autodesk to deploy a hotfix...but I haven't heard anything regarding this happening in 2013...???
Any experience or thoughts on this?
Thanks in advance,
Kyle
Hi and welcome to the group!
When posing a question about crashing and performance type issues, it's usually helpful to post as much information about your system specs as possible. In this case, on the machine or machines where you've seen the problem. Also things like, are you using Vault? How large is the model you are working with?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Understood. Thanks.
Laptop Specs:
Inventor Pro 2013
Vault Pro 2013
Dell Precision M4700
Windows 7 64-bit, SP1
Intel i7 @2.6GHz
16 gb RAM
Nvidia Quadro K2000M
We'll keep the desktop out of the conversation for the moment, as we currently do not have access to them, nor are we certain we can reproduce the error on the desktop.
To this point, the models are simple sheet metal parts (545k, for example), with maybe a couple of bends and a few holes. We have also encountered the problem with assembly drawings as well.
I am an end-user, so I am not quite up-to-speed with all the behind the scenes configurations, implementations, etc., or the lingo, so please bear with me. I will gladly send screen shots, config files, etc., provided I can access them.
Kyle
Ok,... I have to ask. Did you submit any of the crash reports to Autodesk? Is your company on subscription?
Can you post one othe parts/assemblies that you know you had the issue with? Maybe if we play with it something will jump out.
Chris Benner
Could you change the graphics options from Performance to Compatibility in Hardware page within Application options and have a try?
Thanks for the suggestion . . . however, we think we managed to solve this internally. Turns out we had to migrate our XML styles files directly from Vault into Inventor instead of grabbing them from the file server. This seems to have resolved our issue, at least for the time being.
Thanks again,
Kyle
Good to hear! Hope it stays fixed. 🙂
Chris Benner
