I purchased my Inventor 11 license in 2006 and have recently upgraded to Windows 7. During the pre-installation check it gives me the error "Unsupported operating system". I have spent searching on the web and the Autodesk website, but got mixed answers about the compatibility of Inventor 11 with Windows 7. Some have said that it can be made to work (not sure if there meant Inventor 2011) .
If there is any way to install Inventor 11 (purchased in 2006) in WIndows 7, please let me know.
It's not supported by Autodesk. You might try 32 bt compatibility mode in Win7
Make sure you install using these tips:
Hmm, if Inventor is not supported in Windows 7, what is this table referring to?
Oh and I just tried everything in the table cited in the post and nothing works. Even going to a local admin account (enabling it) and I still get the unsupported operating system for Inventor 11 and this is on Win 7 64 bit pro.
So I'm going to tell my end user unless someone has a solution that we can't support Autodesk Inventor 11 on Windows 7 since I just can't get it to install period.
This is very very ambiguous in the posts I've seen in terms of "it works" or it doesn't. The below says it does unless I'm really misreading it, various posts all have the same issue where the pre-installation check fails.
nventor version | OS name | OS service pack | |
32 bit | 64 bit | ||
R2011 | Windows XP | Sp3 | Sp2 |
Windows Vista (all flavors) | Sp2 | Sp2 | |
Windows 7 (all flavors except Windows 7 Starter and Windows 7 Home Basic) | Yes | Yes |
thats 2011 not Inventor 11
Inventor 11 is different from 2011
DarrenP
IV 11, purchased in 2006 and IV 2011, released in March-April of 2010, are very different in terms of hardware and OS requirements.
Your user needs to go back to XP, or buy IV 2011 (last years release) or buy IV 2012 (current release). If your user had stayed on subscription, he could have migrated to the new versions (or stayed at the one he liked) as he liked.
My guess is that IV 11 is old enough that there is no longer upgrade pricing available. Talk to the reseller to get an accurate quote.
Steve Walton
I have Inventor 11 (not Inventor 2011) on my Windows 7 laptop. A friend of mine figured out how to do it and it works fine. All I know is he had to use "emulate XP mode" or something like that. I'll post a link if he remembers where he found out how to do it.
