We just switched to Inventor 2013.
What in the set up could be causing poor graphic performance (chugging, parts dissapearing when rotating model) - we have few stations with the same parameters, some perform well some as above?
Please post a sampling of the system specs of the systems that are having troubles.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I am having a similar problem. IV 2012 works fine. IV 2013 is essentially unusable. Pan and orbit take minutes to update. Features seem to work ok. Adding a fillet or hole is about the same as 2012. The view cube also takes almost a minute to update a view, even the home view.
I would like to start using 2013 and am reluctant to remove 2012 since it is working and 2013 is not. My system meets requirements for both:
System | |||||||||||||||
Storage | ||||||||||||||||||
Graphics | |||||||||||||||||||||||||||
Network | ||||||
The forums seem like a good place to start, but I have seen that many others are having a similar issue and I see no resolution so far.
Anyone have thoughts on this?
Are these service packs for Autodesk or Windows? How do I check for these?
I just uninstalled IV2013 and downloaded and installed it again. It should be the latest available.
Bradley, you could well be hitting the limits of that pc tbh.
looking for DX4300 I get this spec:
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113104
The Radeon 4650
http://www.videocardbenchmark.net/high_end_gpus.html (benchmark)
is v low powered compared to what Inventor really needs (and can only guess the 4600 is even worse).
No idea why your spec say's you've allocated 3711MB ram to be shared with the graphics card - personally would suggest nocking that down to leave as much of the 8gb left to be system ram and have the gpu just use its on-board memory. I would also try updating the drivers - the one listes is about 6 months old. might also try disabling the 2nd monitor to see if it helps at all (give as much processing power to 1 screen and Inventor instead of trying to deal with displaying info on 2 screens).
AMD Phenom II X4 810(2.6GHz)
http://www.cpubenchmark.net/singleThread.html (benchmark for single-threaded application)
is pretty awful too, compared to most modern cpus.
at the end of the day, it's a 3-4 year old system spec that was only "average" speed when new. Sorry to say it, but could well be the case of needing new hardware.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
The problems are with extremely simple models, like an extruded rectangle. The reqs for 2012 are not much different from 2013, but if you're right, I will stay with 2012 until enough issues force me to update my system.
In the meantime, I am going to the install forum to find out why double clicking the msp files doesn't work.
DirectX10 is not helping as well. You probably have a slow hard-drive as well.
Open your task manager and look for any programs/services that are using a lot of resources. Having items running in the back-ground and a nice picture on your moniter doesn't help either.
You can also turn off all the "bling" on your system:
Start>Control Panel>System Properties>Advanced>Performance>Settings>Adjust for best performance
Defrag your system and clean all temp files / directories.
Hello all,
it seems we are some users in this forum to have Inventor 2013 which become painfully slow even to extrude a simple cube...
Refer to this : http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2013-really-slow/m-p/3709580#M454755
Maybe our PC spec are not the best but what I can't understand is:
" Why Inventor 2012 was running well and Inventor 2013 is painfully slow... Something is wrong.. How could be a computer be at ground with only a simple function and only one version more.!! "
Something other, here in my office we are 6 users, only 2 ( including me)have this slowdown problem with same PC specs, same hotfix, ...
Cheers,
A number of users have had simular problems. It seems the IPJ file is either corrupt or pointing to directories that no longer exist.
Either editing the Project File or deleting and creating a new Project File seems to have solved their problem.
hello Blair,
Thank you for your answer, I will try to work on this...
Our files structure in our actual vault project is :
Work folder | -> Libraries folder
| -> Content center folder
| -> iam, ipt, dwg.. folder
| -> project.ipj
+ Template and style & material/color libraries on a network drive
When trying to create a new vault project with Inventor 2013, it seems that the work folder should not include librariess and content center files so that struture should be :
Johndoe folder | -> Libraries folder
| -> Work folder --> iam, ipt, dwg.. folder
| -> project.ipj
I am right? In that case I should recreate my project files... and modify our vault configuration to point to the new work folder... Is this type of configuration new to inventor 2013 or was our Inventor 2012 project files not create as it should been...
In our actual project, the virtual folder is defined as "$", but now Inv2013 do not accept $... What should I put in this ? What is the function of the virtual folder?
Many thanks in advance for your help !
Jonathan.
I am not up on Vault, but we normally map folders on the server and give definitive paths.
Any folders within the work directory can be edited. We try to keep items that we don't want edited in Libraries, this keeps them as read-only.
Try using the default IPJ and do some test modeling (even using the samples supplied with the install) on the machines that are giving this problem. See if its the machine, or the network and possibly your existing Project File.
