Inventor General Discussion
Distinguished Contributor
Infoseeker
Message 1 of 14 (588 Views)
Installed INV 2013 - very slow.
588 Views, 13 Replies
12-04-2012 11:25 AM
We just switched to Inventor 2013.
What in the set up could be causing poor graphic performance (chugging, parts dissapearing when rotating model) - we have few stations with the same parameters, some perform well some as above?
cbenner
Message 2 of 14 (585 Views)
Re: Installed INV 2013 - very slow.
12-04-2012 11:42 AM in reply to: Infoseeker
Please post a sampling of the system specs of the systems that are having troubles.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Member
bradleydawson
Message 3 of 14 (535 Views)
12-12-2012 08:08 AM in reply to: Infoseeker
I am having a similar problem. IV 2012 works fine. IV 2013 is essentially unusable. Pan and orbit take minutes to update. Features seem to work ok. Adding a fillet or hole is about the same as 2012. The view cube also takes almost a minute to update a view, even the home view.
I would like to start using 2013 and am reluctant to remove 2012 since it is working and 2013 is not. My system meets requirements for both:
System
 ManufacturerGateway
 ModelDX4300
 Total amount of system memory8.00 GB RAM
 System type64-bit operating system
 Number of processor cores4
Storage
 Total size of hard disk(s)2011 GB
 Disk partition (C)393 GB Free (914 GB Total)
 Media drive (D)CD/DVD
 Disk partition (E)2 GB Free (124 GB Total)
 Disk partition (F)54 GB Free (58 GB Total)
 Disk partition (X)393 GB Free (914 GB Total)
Graphics
 Display adapter typeATI Radeon HD 4600 Series
 Total available graphics memory4735 MB
 Dedicated graphics memory1024 MB
 Dedicated system memory0 MB
 Shared system memory3711 MB
 Display adapter driver version8.970.100.3000
 Secondary monitor resolution1920x1080
 Primary monitor resolution1280x1024
 DirectX versionDirectX 10
Network
 Network AdapterMarvell Yukon 88E8071 PCI-E Gigabit Ethernet Controller
 Network AdapterRealtek 8185 Extensible 802.11b/g Wireless Device
The forums seem like a good place to start, but I have seen that many others are having a similar issue and I see no resolution so far.
Anyone have thoughts on this?
Distinguished Mentor
john.retzlaff
Message 4 of 14 (532 Views)
12-12-2012 08:15 AM in reply to: bradleydawson
Did you install SP1.1 and update 1 for SP1.1?
John Retzlaff
Member
bradleydawson
Message 5 of 14 (527 Views)
12-12-2012 08:28 AM in reply to: john.retzlaff
Are these service packs for Autodesk or Windows? How do I check for these?
I just uninstalled IV2013 and downloaded and installed it again. It should be the latest available.
john.retzlaff
Message 6 of 14 (524 Views)
12-12-2012 08:30 AM in reply to: bradleydawson
sam_m
Message 7 of 14 (518 Views)
12-12-2012 08:46 AM in reply to: bradleydawson
Bradley, you could well be hitting the limits of that pc tbh.
looking for DX4300 I get this spec:
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113104
The Radeon 4650
http://www.videocardbenchmark.net/high_end_gpus.html (benchmark)
is v low powered compared to what Inventor really needs (and can only guess the 4600 is even worse).
No idea why your spec say's you've allocated 3711MB ram to be shared with the graphics card - personally would suggest nocking that down to leave as much of the 8gb left to be system ram and have the gpu just use its on-board memory.  I would also try updating the drivers - the one listes is about 6 months old.  might also try disabling the 2nd monitor to see if it helps at all (give as much processing power to 1 screen and Inventor instead of trying to deal with displaying info on 2 screens).
AMD Phenom II X4 810(2.6GHz)
http://www.cpubenchmark.net/singleThread.html (benchmark for single-threaded application)
is pretty awful too, compared to most modern cpus.
at the end of the day, it's a 3-4 year old system spec that was only "average" speed when new.  Sorry to say it, but could well be the case of needing new hardware.
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
Member
bradleydawson
Message 8 of 14 (505 Views)
12-12-2012 10:21 AM in reply to: sam_m
The problems are with extremely simple models, like an extruded rectangle. The reqs for 2012 are not much different from 2013, but if you're right, I will stay with 2012 until enough issues force me to update my system.
In the meantime, I am going to the install forum to find out why double clicking the msp files doesn't work.
blair
Message 9 of 14 (485 Views)
12-12-2012 04:48 PM in reply to: bradleydawson
DirectX10 is not helping as well. You probably have a slow hard-drive as well.
Open your task manager and look for any programs/services that are using a lot of resources. Having items running in the back-ground and a nice picture on your moniter doesn't help either.
You can also turn off all the "bling" on your system:
Start>Control Panel>System Properties>Advanced>Performance>Settings>Adjust for best performance
Defrag your system and clean all temp files / directories.
IV2015 up2 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Active Contributor
jonathanruffray
Message 10 of 14 (448 Views)
Re : Installed INV 2013 - very slow.
12-17-2012 09:37 AM in reply to: Infoseeker
Hello all,
it seems we are some users in this forum to have Inventor 2013 which become painfully slow even to extrude a simple cube...
Refer to this : http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2013-really-slow/m-p/3709580#M454755
Maybe our PC spec are not the best but what I can't understand is:
" Why Inventor 2012 was running well and Inventor 2013 is painfully slow... Something is wrong.. How could be a computer be at ground with only a simple function and only one version more.!! :smileysad: "
Something other, here in my office we are 6 users, only 2 ( including me:smileymad:)have this slowdown problem with same PC specs, same hotfix, ...
Cheers,
Autodesk Product Design Suite Ultimate 2013
Win 7 Pro 64 bits SP1
Bi-Xeon E5520 (2x Quad-core @2.27GHz)
Quadro Fx 1800 768Mo GDDR3
6Go Ram DDR3 667MHz ECC
