docume^1\vm-designing\locals^1\temp\autodesk inventor 10 setup.log" for details. I have done everything that has been recomended to uninstall Inventor beta 10.
That's the setup log:
'[4/11/2005 22:07:30] === Installation started on VASILE-PA3CE9IZ by VM Designing ===
[4/11/2005 22:07:30] [Info] Windows Installer upgrade is not required
[4/11/2005 22:07:30] System Version = 3.0.3790.2601
[4/11/2005 22:07:30] Installation skipped: MSI Runtime 3.0
[4/11/2005 22:07:30] [Info] .NET Framework Runtime upgrade is not required
[4/11/2005 22:07:30] System Version = 1.1.4322.2032
[4/11/2005 22:07:30] Installation skipped: .NET Framework Runtime 1.1
[4/11/2005 22:07:30] Installation skipped: .NET Framework Runtime 1.1 SP1
[4/11/2005 22:07:30] [Info] MDAC upgrade is not required
[4/11/2005 22:07:30] System Version = 2.81.1117.0
[4/11/2005 22:07:30] Installation skipped: MDAC 2.7
[4/11/2005 22:07:30] Installation skipped: Microsoft WSE 2.0 Runtime
[4/11/2005 22:07:30] Installation started: Autodesk Inventor 10
[4/11/2005 22:07:30] Command = msiexec /i G:\inv1_series10\bin\acadfeui\Inventor.msi /L*v C:\DOCUME~1\VMDESI~1\LOCALS~1\Temp\AIS10Install.log
[4/11/2005 22:09:49] [Error: 1603] Fatal error during installation.
[4/11/2005 22:09:49] Installation failed: Autodesk Inventor 10
[4/11/2005 22:09:49] Installation aborted
[4/11/2005 22:09:54] === Installation ended ==='
Thank you for help.
